Atmel 89C51 programming in C example
8051Help
Nov 27, 2015
I need to write only numbers (every second) in string on display (memory mapped on 0x8001 adress) which are divding with 2 I must use counter not delay () for interrupt ...
#include <reg51.h>
#include <math.h>
typedef unsigned char byte;
byte a[3]= {2,1,8};
byte counter, frequency,displ;
int i=0;
byte xdata display _at_ 0x8001;
sbit switcher=P0^0;
void Inic(void) {
EA=1;
ET0=1;
TMOD=1;
TH0=0x3C;
TL0=0xB0;
TR0=1;
counter=1;
frequency=0;
void timer0(void) interrupt 1 using 2 {
TR0=0;
TH0=0x3C;
TL0=0xB0;
TR0=1;
if(switcher) {
if(!(--counter)) {
counter=frequency;
display=displ;
void main(void) {
Inic();
while(1) {
if(switcher) {
for (i=0;i<3;i++) {
if(a/2) {
displ=a;
frequency=20;
Anon_LG
Jun 24, 2014
453
Is this a question or an example? I will assume a question. I order to produce a delay of the correct length in C without using a delay function, you do indeed use a for() loop. Hopefully you are using AVR studio, this includes a built in code analyser and step by step feature. Using a while loop instead I believe that While(int i < 54){i++} will yield a delay of about 1 milisecond, I could be wrong though, I say a lot of wrong stuff (THIS IS FOR A 1MHZ SYSTEM). If you are using a for() loop, fill it with ";"'s for nop's, and test on the step by step feature.
I hope this helps,
8051Help
Nov 27, 2015
Hi, I solved. But now I have problem with 1 second per number.
I got printing all numbers like results on display. So I need 1second interrupt per number like results
COde below is little bit different..But working... Only problem is 1 second per number
Code:
#include <reg51.h>
#include <math.h>
byte a[8]= {7,5,16,3,1,4,11,9};
byte counter;
byte started = 0;
int i=0;
sbit switcher=P0^0;
void Inic(void)
EA=1;
TMOD=1;
TH0=0x3C;
TL0=0xAF;
TR0=1;
counter=1;
TH0=0x3C;
TL0=0xAF;
counter--;
if(counter == 0)
counter = 20;
if(started == 1)
if(i < 8)
if(!(a[i]%3) )
display=a[i];
i++;
if(i == 8)
ET0 = 0;
TR0 = 0;
started = 0;
void main(void)
Inic();
switcher = 1;
while(1)
if(switcher == 0)
if(started == 0)
started = 1;
i = 0;
counter = 20;
TH0=0x3C;
TL0=0xAF;
ET0=1;
TR0=1;
