ATX power supply to bench supply conversion
K
Kingcosmos
Not sure if this is the best group for this. I found several articles
on the process of using an ATX power supply and convert it to a bench
supply. The problem I am having is that the wire color codes and pin
outs are not standard ATX. I looked several places, including this
website, to see if I could find out what the pin outs would be.
It is a LiteOn 140W PSU with +/-5V, +/-12V, +18V, and +5V standby
(underside of the PSU). I actually had to open it to see what wires
were what voltage. The board actually has them listed as:
6 Red: +5V
5 Black: Ground
1 White: +18V
1 Yellow: -12V
1 Purple: -5V
1 Grey: PG, I am guessing 'Power Good'
1 Orange: +12V
2 Brown: P/C and F/C (not sure what these are supposed to be)
The pinouts from 1 to 20 are:
Red
Black
Red
Black
Grey
Red
Orange
Yellow
BLANK
White
Brown
Black
Black
Black
Purple
Red
Red
Red
Brown
BLANK
Any ideas? I am out of them. Thanks in advance.
Lionel
6 Red: +5V
5 Black: Ground
1 White: +18V
1 Yellow: -12V
1 Purple: -5V
1 Orange: +12V
Red
Black
Red
Black
Grey
Red
Orange
Yellow
BLANK
White
Brown
Black
Black
Black
Purple
Red
Red
Red
Brown
BLANK
Um. What's your actual question? Your colour coding looks correct at a
glance, so you know which voltages should be on which wires. As you
guessed, PG = "power good", so all you need to do it short the grey
wire to a black wire (you can use a 1K resistor if you're feeling
paranoid), & the it'll power up just fine. I have a couple of PC PSUs
set up the same way on my own bench.
K
Kingcosmos
W "Some people are alive only because it is illegal to kill them."
. | ,. w ,
\|/ \|/ Perna condita delenda est
---^----^---------------------------------------------------------------- Hide quoted text -
- Show quoted text -
I guess it is ok; however, every single site I go to does not show
this pin out or color coding for an ATX power supply. Real quick,
Blue is -12V on every site that I have seen...among others.
The question I really wanted to ask concerned the brown wires. Not
sure what they are supposed to be. The board says P/C and F/C. If
shorting the grey wire to ground is all I need to do, I will set that
up and just measure them with a Fluke.
F
Franc Zabkar
6 Red: +5V
5 Black: Ground
1 White: +18V
+18V is not a standard ATX voltage. Furthermore, the LiteOn has no
+3.3V rail. Could this supply be for an industrial PC ???
1 Yellow: -12V
1 Purple: -5V
1 Orange: +12V
Power/Control ??? Fan/Control ???
- Franc Zabkar
Meat Plow
A 140 watt supply in an industrial PC? :)
Maybe it's out of an Apple?
#1 Offishul Ruiner of Usenet, March 2007
#1 Usenet Asshole, March 2007
#1 Bartlo Pset, March 13-24 2007
#10 Most hated Usenetizen of all time
Pierre Salinger Memorial Hook, Line & Sinker, June 2004
COOSN-266-06-25794
Lionel
That's what I'd do.
K
Kingcosmos
Success!
The grey wire appears to be power good so that should be an output. I
connected the only +5V coming up (which I think is the standby
voltage) to the brown wire P/C (I agree-- power control), and the rest
of the rails came up.
Everything looks good. Still not sure about what the supply actually
is.
F
Franc Zabkar
Success!
In a regular ATX PSU, the PS_ON pin is shorted to ground to turn on
the supply.
is.
Could the 1-wire 18V rail be for an LCD panel or touch screen ???
Point of Sale system ???
- Franc Zabkar
JW
Sure! We ship industrial nema-4 systems with even less power. 50-80 watt
power supplies and mobile processors.
