automotive electrical noise detector
PDRUNEN
Hi Group,
I am working on a project which will detect if a automobile is running. The
output of sensor would be a TTL high for running and a TTL low for not running.
The circuit will be inside the car, most likely in the glove compartment or
storage compartment. It will not be connected to the automobile and run off of
batteries.
My thoughts are to use a common 455KHz IF filter and amplitude detect or a 10.7
MHz IF filter and do the same.
Which frequency would be better and/or easier to design around? (455KHz or
10.7MHz). How about VHF or a super-reg with a wide bandwidth?
How much gain would a stage following an IF filter require such that it could
be used as a level detect?
Other suggestions? (I want to stay away from any connections into the car).
Paul
Paul Burke
Turn the music off and listen? Change from a Rolls to a banger? Hang a
small bell in the engine compartment? Look at the oil pressure light?
Paul Burke
John G
PDRUNEN said:
Hi Group,
running. The
running.
compartment or
run off of
batteries.
or a 10.7
(455KHz or
it could
car).
Paul
Wot's youre real objective?
Most cars have enough Idiot lights to tell you they are turned on and
running or not.
Robert Baer
Paul Burke
How about a solid state air flow detector (vane) in the tail pipe, or
is that too complex?
mike
PDRUNEN said:
Hi Group,
batteries.
Paul
ONce had a boat tachometer that had a tunned diode receiver that ran on
ignition noise.
mike
Return address is VALID.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
http://nm7u.tripod.com/homepage/te.html
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Bunch of stuff For Sale and Wanted at the link below.
http://www.geocities.com/SiliconValley/Monitor/4710/
mike
