AVANTEK YIG bias
aduro
Hi all.
I have a couple of AVANTEK YIG oscillators, models SF6- 0991 and AV7204M
Both are 2 – 4 GHz units.
None of the oscillators have their pins marked, but FM coil, Main coil an
heater are easily identifiable.
Does anyone have information about bias connection for these units?
Most AVANTEK’s have +15V and –5V connected to pins 1 and 2 (Clockwise fro
SMA), but these units have an 18V 1W Zener diode connected from pin 2 t
casing.
It looks like these Zeners are there to protect pin 2 from over voltage
above 18V, which doesn’t make much sense, unless Bias pins are swapped o
these units (+15V on Pin 2 and –5V on pin 1)
Anyone can help?
Regards
Augusto Duro
This message was sent using the sci.electronics.design web interface o
www.Electronics-Related.com
rex
Hi all.
I have a couple of AVANTEK YIG oscillators, models SF6- 0991 and AV7204M,
None of the oscillators have their pins marked, but FM coil, Main coil and
Most AVANTEK’s have +15V and –5V connected to pins 1 and 2 (Clockwise from
SMA), but these units have an 18V 1W Zener diode connected from pin 2 to
casing.
It looks like these Zeners are there to protect pin 2 from over voltages
above 18V, which doesn’t make much sense, unless Bias pins are swapped on
Anyone can help?
Regards
Augusto Duro
I looked up data for the AV-7204: 2-4 GHz YIG tuned Osc. As you
described, the first pin gets +15V. The 2nd (bias) pin has this note:
"Terminal Vc requires a linear voltage Ramp proportional to frequency.
The voltage at 2 GHz is factory selected within the range +7 to +13
volts and the voltage at 4 GHz is +15.0 volts."
So, I think, basically you want to fire it up with an adjustable voltage
on the 2nd pin. Tune to the low end of Freq with the tune current, and
adjust the voltage on the 2nd pin for max power output. The voltage on
this pin should then vary linearly between this voltage and +15 V as the
tune current is ramped across the range.
John Miles
Hi all.
Both are 2 ? 4 GHz units.
Most AVANTEK?s have +15V and ?5V connected to pins 1 and 2 (Clockwise from
casing.
above 18V, which doesn?t make much sense, unless Bias pins are swapped on
these units (+15V on Pin 2 and ?5V on pin 1)
It might be there to keep inductive spikes from the tuning or FM coil
out of the driver circuitry, or to keep negative-going voltages out of
the expensive stuff.
Here's the AV7204 info from my Avantek book:
http://www.speakeasy.net/~jmiles1/ke5fx/avoct.pdf
(2 pages, 220K)
-- jm
Similar threads
Replies
2K
aduro
Replies
2K
Pierre-François \(f5bqp_pfm\)
Replies
2K
Peter Baltus
