Back to Back Tantalum Caps
PaulCsouls
I was recently looking at a design that had two Tantalum caps reversed
biased to each other to make a bipolar cap. I know tantalums can work
down to -1v and don't need a DC bias the way aluminum electrolytic
caps do but this looked strange. What are the pitfalls to this
method.
Paul C
John Larkin
method.
Paul C
If there's an unknown DC polarity and a small AC signal, it's OK. If
the AC across the combination gets to be larger than a volt or so the
the capacitance will change during each AC cycle (as the
reverse-biased cap goes from being a capacitor to being a resistor)
and that can cause distortion and other weirdness.
The potential nonlinearities are complex and depend on the situation.
John
Pooh Bear
method.
The cost of tantalum caps perhaps ?
They *don't* need bias ? I rather thought they did to perform properly. In
fact, under the right condirions, aluminium electrolytics work well for
audio coupling under zero bias conditions. You need a big cap to ensure
that the ac component of the signal is essentially miniscule but you might
be interested to know that almost every single top-end modern audio mixing
console uses unbiased aluminium electrolytics to couple signal - right at
the very top-end too. I'm talking $100,000 + products here.
I do know an audio company that ( many years ago ) used back to back
tantalums for coupling that biased their centre junction to ensure biasing
polarity. Today that would be considered esoteric overkill and financial
suicide for a large product.
I have used that technique with a pair of aluminium electros though, where
the DC offset voltage at the source is subject to tolerances. Works
nicely.
Graham
Tam/WB2TT
method.
Paul C
You might be better of putting a low Vf diode across each cap to keep the
cap from ever conducting forward current.
Tam
John Larkin
Tam
Makes it more nonlinear in many situations.
John
PaulCsouls
nicely.
Graham
I'm just following Ian Sinclair's Passive Components for Circuit
Design. He says that Alumunium Electrolytics require a DC polarizing
voltage to maintain the insulating film and for Tantalum Caps he says
"Tantalum electrolytics can be used without any DC bias and can accept
a small reverse voltage, typically less than 1.0v." But he doesn't get
into the frequency characteristics and I would guess biasing would
improve the usable bandwidth.
Paul C
PaulCsouls
John
That's my intuition. I would pay for a bipolar cap with a data sheet
to give me that warm fuzzy feeling of knowing what's going on.
Paul C
PaulCsouls
Tam
Yes, or clamp the signal to +/- 0.7 volts.
Paul C
Tam/WB2TT
John
Wouldn't the cap acting as a diode be as bad or worse? He does not say what
this is for; so, I am assuming he wants to put 60 Hz through it, which I
have done at 24VRMS..
Tam
John Larkin
Tam
Without knowing the DC bias, AC current and frequency, and the
capacitance it's impossible to say how weird or maybe not weird this
would behave. It's complex.
John
PaulCsouls
Tam
It was in an AGC circuit. Basically a low pass filter with the caps in
series to ground two 47uF caps and 1k resistor so a 4Hz 3dB. Not very
demanding with respect to distortion or tolerances. I was just curious
about how the limitations of the configuration.
Paul C
Tam/WB2TT
Paul C
What I had done was put 2 caps back/back with diodes to get a NP 200uF
capacitor for use with a reversible 2 phase electric motor in an antenna
rotator. Worked fine. I know of people who have don this with speaker
crossover networks, but as John points out, probably not a good idea.
Tam
Rich Grise
Aluminums can do this all day - that's what a "non-polar" cap is -
essentially two aluminum electrolytics back-to-back in one package.
The OP was asking about doing that with tantalum.
Nobody seems to know. ?:-|
I'd say, look for followups on the performance of the circuit design the
OP saw with that configuration, or put a couple on the bench in the
breadboard with some kind of test setup, and see what happens.
Cheers!
Rich
Pooh Bear
Design.
Any link ?
Oh well. That means almost every piece of current pro and consumer audio is
built wrong then !
Alumiums are good for a few 100mV reverse volts typically. Perfect for split
supply audio apps.
But he doesn't get
What 'frequency characterisitcs' ? Bias affects bandwidth ? Some very strange
ideas here.
Maybe this Mr Sinclair is one of those audiophool gurus ?
Graham
N
Nico Coesel
I don't even want to know. If possible, I avoid tantalum caps because
they short out when they fail. They can also burn a hole right through
the PCB if you are unlucky.
When it comes to distortion, I think the best idea is to read the
datasheet and determine how the capacitance changes with the voltage.
N
Nico Coesel
method.
This may be interesting reading material:
http://www.epcos.com/inf/20/40/db/tec_03/01070134.pdf
I
Ian
Paul C
A better method would be to put a bias resistor to a sufficiently large bias
voltage
connected to the junction of the 2 capacitors. That way, both are always
operating
correctly biased.
Regards
Ian
PaulCsouls
Any link ?
built wrong then !
supply audio apps.
ideas here.
Graham
The bias / bandwidth idea is one of my fool ideas. Ian Sinclair's book
is recommended by Bob Pease in his Troubleshooting book, so it has
been proofread by someone with some experience in the field.
Paul C
I'd be really smart, if I wasn't so stupid.
Similar threads
K
Replies
2K
Tim Williams
Replies
41
5K
Nico Coesel
N
Replies
20
3K
John Devereux
Replies
7
5K
Alan Rutlidge
