also microchips usually take more power than just small IC's
Todays µ-chip powder drain in an idle sleep mode is insignificant in almost all cases, the batteries self drain is larger...
Microchip has active current chips in the 150µA range with 10nA pull in sleep, hardy a concern in most any project... The count display will be the real drain on the system...
there are some simple counter IC's that will count up to 255 and more
But, you still need the display drivers to make the count visible, and the requirement for an admin type reset further complicates it... Sure you could do it with more discreet chips, but I hate fighting the future as a single micro will do it all for about a $3... I know the age old fight of just coping out and using a micro when discreet components will work irks many old timers, but it's really the future of electronics $ for $ and labor wise and I'm not one to fight it...
Back to gary2530, you have a tall order for the design and one that is almost certainly beyond your means unless you really start crunching the books and websites for a crash coarse in electronics...
Overall it's not an overly complicated circuit to design with a micro, in fact it's pretty basic and small loop as you are simply watching a single port for a logic transition and counting... The reset device with a login is a little more complicated but unless high security is needed it's still not hard...
please i need component data sheet book ,how can i get 1?
Contact the manufacture of the component
