Basic Scope Q: Auto vs Normal trigger
LanceM
Learning on an older 2 chan 20 MHz analog scope (of questionable
condition), using mostly for automotive t-shooting
Shouldn't I be able to use the Normal trigger setting to get a steady
signal off a 12 V battery? I can get a brief glimmer as I rotate the
trigger level, but can't maintain the trace
No problem/steady trace using the Auto trigger
Thank you,
Lance
K
Kevin Carney
Use normal trigger for a low speed signal (less than approxiamately 60 hz).
Auto trigger will sweep after every sweep. Normal will only sweep when it is
triggered (by the input signal). When you apply dc voltage to the input and
turn the level control, the scope will sweep whenever the level control
(being turned by you) crosses the level of the dc voltage applied. That last
sentence was a mouthful ! Hope you understand.
change .combo to .com for correct email
"We ought always to know precisely why a given job
is done in a particular way, and why it is done at
all, and why it can't be done more efficiently,
if it must be done at all."-- T.J.Watson
Jim Adney
No, you're seeing exactly the right thing.
Normal trigger waits for a trigger event to start a sweep.
Automatic trigger will wait for a trigger event only a certain amount
of time, which depends on the sweep speed. If no trigger event arrives
within this time period, the sweep will trigger "automatically" and
then start the waiting period again.
Since you're watching a DC signal there is no trigger event so under
Normal Trigger it will just wait forever, and you see nothing.
Both modes have their useful moments, but it's important to understand
the difference between them.
Similar threads
