battery decorations converted to mains tranformer
Henhead
Dec 17, 2015
I want to create a Xmas scene for my fire place. I want to wire a number of battery Christmas decorations together and run it off a single multi voltage adapter.
The decorations are led lights only (some change colour) ranging from led tree light (3 x aa) and a number colour changing snowmen (2 x aa) and snow men and robins (3 x LR44 Button)
I wanted to create a box stand that they will be stuck down to and then wired underneath (hidden) and run off a single adapter.
Is this possible? Safe? If so how would run the wires?
multiple feeds off one wire or chain each positive feeding the next and same with neg?
GPG
Sep 18, 2015
452
You could run them off a 4.5V wall wart all in parallel, Operating off batteries I dont think the current will be an issue
snowmen (2 x aa)
This will need couple of diodes to drop the voltage,
Sadlercomfort
Ash
Feb 9, 2013
424
Each light would have an led and a resistor to create a voltage drop and limit the current. (Apart from the button batteries)
So each circuit in each light is already designed for there battery voltages. If you can create several different voltage rails for each light it would be simpler.
If you used a single voltage for them all, you would need to find calculate which resistor is needed to create the right voltage drop for each(In addition to the resistors already in each light).
Diodes are useful to drop the voltage slightly, but it's more practical to use a resistor.
14,479
That's not really the issue
the plugpack will be wired into the existing battery terminals of each unit so that it still powers the unit for the colour changes etc
As @GPG said, a diode will effectively drop the voltage enough to the lower voltage light unit
no is isn't,. because a resistor will also current limit and in this case that also isn't an issue .... a diode is ideal :)
Sadlercomfort
Ash
Feb 9, 2013
424
Okay Dave, would the diode voltage drop be unreliable though depending on the current?
Martaine2005
May 12, 2015
5,288
Hi Ash,
the diode would drop the voltage by approx 0.7v for each diode.
The resistors are more for limiting the current.
So two diodes at 0.7v is 1.4 volt drop immediately.
As for reliability, rectifiers are used in all AC to DC units.
So I would guess they are reliable.
Martin
Sadlercomfort
Ash
Feb 9, 2013
424
I read somewhere before about the diode voltage drop changing when the load current changes. But I guess that doesn't apply here.
So its be possible to use one voltage supply and create a series network of diodes to provide the necessary voltage drop
Martaine2005
May 12, 2015
5,288
I would guess that you can.. But obviously very inefficient. lots of diodes...
But yeah, it's possible..
Martin
Martaine2005
May 12, 2015
5,288
But in this case, the OP has 4.5v and 3v. So two diodes are perfect for a voltage drop..
Martin
Martaine2005
May 12, 2015
5,288
Sorry Ash, not trying to tell you how to suck eggs! I think you are more knowledgeable than I am!
Sometimes, two heads are better than one!!
Martin
14,479
the current in the circuit will also vary with varying voltage and load through a limiting resistor ;)
Martaine2005
May 12, 2015
5,288
there sure is ... am always learning new things :)
Put yourself in mine and all other 'learners' shoes Dave!
We will never know half of what you have forgotten!:p:p
So catching up is a no go! Going forward is likely!..But not guaranteed in my case:D
Uncle Chris only guides me after several large liquified grapes:eek:
Martin
