Battery life discharge rate
Christopher
Hello Everyone,
I made a semi-passive filter circuit that uses one 1.5 volt AA cell
with a constant drain of one milli-amp. If the 1.5v AA cell remained
above 1.1 volts for a year I won't bother using a on/off switch.
Will a AA last a year?
Are the Alkaline cells better in the long term than Heavy Duty AA?
Is the decay rate of a manufacturer's cells "honestly" documented some
where?
Thank you,
Christopher
Temecula CA.USA
http://www.oldtemecula.com
ehsjr
Christopher said:
Hello Everyone,
Nope. Battery capacity for an alkaline AA is about 2850 maH
http://data.energizer.com/SearchResult.aspx
At 1ma, it will last a whole lot longer than 2850 hours, but
there are 8760 hours in a year.
Check the url, make your own decision. Cost may come into
the equation!
where?
You mean self-discharge or shelf life figures?
Probably irrelevant in any event - these small batteries
are use & toss, so you keep extras on hand.
Ed
Jasen Betts
Hello Everyone,
more like 3 to 6 months. with a D cell you could get a year.
yes.
where?
the use-by date is some indication.
Bye.
Jasen
