Baumatic Microwave Fuses
gingadunc
My Baumatic microwave has recently come out of it's warranty and
(surprise, surprise) it has stopped functioning properly. The display
and grill etc work fine but not the m'wave itself. Upon stripping it
down I found that the magnetron supply fuse has blown. I have tried
Baumatic spares for a replacement and have been quoted £42 - FOR A
FUSE!!! The fuse type is a TUV 5kV 700mA glass fuse about 6x32 mm.
Can anybody give me any advice on where to get hold of one or a
suitable replacement?
Many thanks in advance!!
p.s it will also get the wife off my back!
TheDragon
Not found 700mA
From RS I found
But did find 800mA anti surge
http://tinyurl.com/5kjd6
Or 750mA
http://tinyurl.com/6vbno
More much cheaper 750mA fuses from CPC
http://tinyurl.com/6wy9f
CPC also have a microwave spare dept, maybe they could offer more help.
www.cpc.co.uk
Sam Goldwasser
Or here is the part you need 700mA 5kV. Not cheap though
http://www.donberg.ie/descript/0/07a5kv.htm
Before you blow (no pun...) $20 on a fuse, some testing is needed. While
it's possible that the fuse is the only problem, the likelihood is that
something has failed and the new fuse will just blow instantly.
--- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
+Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
| Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
Note: These links are hopefully temporary until we can sort out the excessive
traffic on Repairfaq.org.
Important: Anything sent to the email address in the message header above is
ignored unless my full name is included in the subject line. Or, you can
contact me via the Feedback Form in the FAQs.
N
NSM
6 x 32 mm is 1/4 x 1 1/4 - standard US size. I disbelieve the 5 KV rating -
which circuit is it wired into?
