best non-electric soldering iron?
the requirement: perform solder joints outdoors, in the winter,
without electricity, up a radar mast.
and the nominations are?
P.S. could a resistance-soldering rig do it, on battery power,in a
form factor that's small/light enough to haul up a radar mast in a
basket?
N
NSM
Gas (butane) or similar. Don't bother with anything that runs on AAs.
| basket?
Why bother? Gas is light, cheap (dollar store) and you could even refill it
up there.
N
John Popelish
basket?
I think I would look for something like this:
http://www.dansdata.com/portasol.htm
More punch per ounce of weight than battery powered units.
James Horn
I second that. I bought one of the early ones (their Technic model)
twenty years ago. It worked fine until a seal failed last weekend.
Gotta get another!
Jim Horn, WB9SYN/6
TimPerry
basket?
how big are the joints?
soldering in the cold can be exasperating.
i use a small oxy-MAP gas torch. it can be a pain dealing with 2 cylinders
but it certainly gets hot enough.
sofie
Jamie:
The (gas) butane soldering irons are the best for what you want...... the
problem with battery operated soldering irons is that they do not produce a
lot of heat for any length of time.... and usually when you only have a few
more joints to solder, the battery DIES. With a butane soldering iron,
when it runs out of gas you just refill it and you are ready to solder again
in a few minutes.and if more heat is needed just turn up the gas and install
a bigger tip.
Jamie
basket?
look for "Cold heat soldering iron"
battery operated and it very fast.
its not good for very fine detailed work but
may work well for your use.
https://www.asseenontvnetwork.com/vcc/coldheat/coldheat/115785/
Bill
I don't think that will do. They barely work indoors.
Small little torch is the only way to go.
-Bill
Jim - NN7K
Also, consider : low temperature solder-- can be melted with a match-
tho NOT advocating THAT technique, would recommend that with a butane
iron, or torch in inclemate weather! And, have used the butane irons
in blizzard conditions, in the Sierras (repairing equipment for the
railroad), useing these. highly recommend them for use in adverse wx!
Jim NN7K
N
NSM
| Jim NN7K
If you can use them in those conditions then no question they're the best.
Everything I have heard about the 4 AA irons is not confidence making!
N
Bill Janssen
Jim NN7K
I have a selction of different sizes of "soldering Coppers" that I heat
with a torch.
They work good and I can control where I put heat. They are however not
easy
to heat with the torch.
Bill K7NOM
Cecil Moore
with a torch.
easy
The "cold heat" soldering iron works on the same principle as
an electric welding machine. Thus, there is the germ of a good
idea there. How about a soldering iron using the same principle
as the "cold heat" soldering machine except run off of 110VAC?
It could be transformer isolated, run on low voltage, and thus
be perfectly safe, but with a nearly unlimited source of power
to overcome the battery power limitation.
N
NSM
Hmm, doing that up a pole in wet, cold weather. Why do I see a Homer Simpson
episode in my mind?
N
John Popelish
with a torch.
easy
Especially while hanging from a tower, 50 feet up. ;-)
Cecil Moore
episode in my mind?
Completely transformer/shielded. Why would it be less safe than a
welding machine?
N
NSM
Simpson
| > episode in my mind?
| welding machine?
Homer and electricity. Not a good combination - ever <G>!
N
