Best Source for TV Schematics??
Jim Thompson
The TV I bought for my office on 9/11/2001 has gone on the fritz...
Panasonic TC-15LT1
Warms up, then flicks back and forth between a perfectly good picture,
then totally washed out. Sound always stays good.
Who's the best source for a schematic? I'm leery of the Russian
sites, which seem to dominate this topic.
...Jim Thompson
Joerg
Hello Jim,
Panasonic TC-15LT1
Hey, since you kill bugs with freeze spray I guess it's time to try it
on the TV. It could be as simple as an electrolytic having become
marginal. Freeze spray is how I found out what caused our little PAL
standard TV to lose PLL lock. I really had to fix that one because we
can't buy them here and it's our sole source to watch old European tapes.
In the old days (meaning >20 years ago) I had good luck by writing
directly to the manufacturer. Nowadays many schematics are sold via
"service manual providers". Don't know what the fees are but a pdf
download shouldn't be too bad.
N
Nico Coesel
Panasonic TC-15LT1
Probably a defective electrolytic capacitor. Buy a can of freeze spray
too cool down components and start cooling down electrolytic caps near
heatsinks. I bet the culprit is close to the HV transformer.
Does slamming the TV help? If yes, check for loose soldering joints.
A schematic is not going to help. A basic understanding on how a TV
works and a not so expensive analog oscilloscope are more usefull.
Jim Thompson
HV? In an LCD flat-screen ?:)
I have been known to completely re-solder a board... successfully ;-)
Duh! I grew up in a radio/TV repair shop ;-)
Finding things on a dense board becomes problematic.
It has an external 15V/4A "power block". I'm beginning to be
suspicious of that.
...Jim Thompson
Chuck Harris
Panasonic TC-15LT1
There is no reason to be leery of the rusky sites. Get your schematic,
and move on.
Televisions are wonderful devices. When they fail, it is almost always
a bad solder joint, or a bad electrolytic. Some times there is some
collateral damage that results from the failure.
Get an ESR meter, and you can check all of the electrolytics quickly.
Freeze spray sometimes helps, but for intermittent, I usually use a fiberglass
stick, and tap here and there until I get a response. I found a bad solder
joint in a 25 year old sony just yesterday, that way.
-Chuck Harris
Joerg
Hello Jim,
Well, they generally do have a high voltage converter for the CCFL
tubes. Not tens of kV but a few kV. I don't know what you mean by
"washed out" though.
Same here. And certainly not with RoHS compliant solder. I can already
see myself resoldering RoHS stuff to get it back to non-RoHS performance.
And figuring out what that highly unobtanium full-custom chip does that
reacted to the cold spray.
suspicious of that.
Easy. Hook a digital scope to it and let it log the 15V in slow motion.
Or use a bench supply and see if the TV repeats the error.
Jim Thompson
Hello Jim,
Loss of contrast.
Doesn't seem to (at least coherently) respond to "slamming".
Bought this set the day of 9/11 so I could keep track of happenings
without leaving my desk... I was in the midst of a big project. So I
doubt if it was built to RoHS.
Natch. I probably should just go buy a new set and forget about it.
The replacement AC adapter alone is $126 :-(
Unloaded it's bouncing around. I'm going to rig up a "T" so I could
watch it while loaded.
I'd use a bench supply but, in my world, 4A is unheard of. All I have
is small supplies good to 300mA.
...Jim Thompson
Bobo The Chimp
Panasonic TC-15LT1
Your problem is easy to fix. Just open the back of the set, and
turn it on. (use a cheater cord if you have to.) Now, rest your left hand
securely on the chassis, and in your right hand, grasp a long-bladed
screwdriver. Using care to ensure that you are in contact with the metal
blade of the screwdriver, insert it decisively under the HV cap on the
picture tube, to ensure that you've fully discharged the HV capacitor.
Good Luck!
Bobo
Joerg
Hello Jim,
Loss of contrast.
That could be a CCFL tube going (or the switcher feeding them).
I just meant the stuff that's coming. With the EU having gone crazy
about RoHS there will be lots of electronics gear shoved onto our market
that is compliant. And that might not be a good thing.
I have seen a small LCD 14-inch TV at a big store (Walmart?) for about
$250. It didn't quite have the contrast that our outdoors tube set does.
That is not a good sign. Either shot or of poor design.
A fully charged car battery might work if the set is happy with about a
volt less. Assuming this is a 15" set I am surprised it needs a 60W supply.
Tim Shoppa
Panasonic TC-15LT1
My two cents: Toss the TV. The world of network TV that you and I grew
up with is gone. The last universally shared experience of US culture
was watching the 9/11 damage over and over again, and we saw enough of
that 5 years ago. What we're left with is a bazillion channels of HDTV
nonsense.
Use the space formerly taken up by the TV to buy some ex-soviet
military technology (maybe not the same sites, but maybe adjacent
ones!) to sit in your office. On E-bay there's a lot of interesting
stuff coming out of Ukraine/Georgia/Russia right now.
Tim.
Jim Thompson
Hello Jim,
[snip]
suspicious of that.
It's 16" letter-box.
...Jim Thompson
Jim Thompson
nonsense.
[snip]
What? And not be able to watch Fox News ?:)
...Jim Thompson
Joerg
Hello Jim,
Wow, wonder why it needs so much more juice than a CRT set.
Regarding power, check this out:
http://www.caiso.com/outlook/SystemStatus.html
It's our CA power grid supply-demand situation on a scorcher day (by
non-Arizonian standars). Under our previous governor the green supply
side line would often have continued flat at 11:00am and it seems we
would have lost electricity by 12:30pm.
Tim Shoppa
Is that the channel that the Huntley-Brinkley report is on now?
Tim.
martin griffith
nonsense.
[snip]
...Jim Thompson
I dont have a TV, almost 4 years now, but I see the UK is going even
more down market with imported US crap
http://www.theregister.co.uk/2006/07/18/tv_spectacular/
OK well, it is Arnulds pitch
martin
Jim Thompson
Tim.
I'm old enough to remember Chet and Dave as *the* standard for news
casting.
...Jim Thompson
Martine Riddle
Panasonic TC-15LT1
I allways ran over to the local library. There is one not too far that had a
pretty complete Sams on hand. A couple of dimes in the machine and I was
off.
Cheers
Rich Grise
casting.
I remmber when they won some award, and Carol Burnett was hosting
that particular presentation, only weeks after they'd had a "Huntley-
Brinkley" parody on the Carol Burnett show, and when she opened the
envelope, she grinned from ear to ear, as only she can do, and proudly
announced, "Buntley-Hinkley".
Cheers!
Rich
