bicolor led driver
Hi all
I need to build a bicolor led driver using a single input that
alternates between 8-12V every 2 seconds. So at 8V, the LED lights to
one color, and at 12V the other. Any ideas will be welcome.
K
krw
Hi all
How about a diff amp:
VCC VCC
V -> V ->
In o-----| |-o 10V
GND
(created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
If you haven't a separate Vcc larger than Vin+Vled, the Vref and Vin
can be scaled with resistor dividers.
D from BC
Hi all
Sounds like a 555 project.
D from BC
pklammer
Hi all
How about with one bicolor LED and one resistor?
If the 8 and 12V are low enough impedance (can sink and source LED
current), and if you can afford a little waste current (heat), and can
supply constant 10V (is the 12V constantly available somewhere?), then
tie one end of a bicolor LED to 10V through some current-limiting
resistance, and the other end to your 8/12V source.
I've done this with an SPST switch and 4 resistors to operate a red/
green LED depending on the switch closure.
