Blown power transformer in Denon DRA-345R Tuner Amplifier
GavinI
G'day all
Someone at work asked if I could look at a Denon DRA-345R Tune
Amplifier that deosn't power up. Turns out to have an open circui
primary winding of the power transformer.
I've not had much luck in sourcing a replacement (in Sydney Australia
so though I could put an 'equivalent' in.
So does anyone know what the secondary outputs voltages (there are 3
and current cappabilities are?
Gavi
Y
Yukio YANO
GavinI said:
G'day all
Someone at work asked if I could look at a Denon DRA-345R Tuner
Amplifier that deosn't power up. Turns out to have an open circuit
I've not had much luck in sourcing a replacement (in Sydney Australia)
So does anyone know what the secondary outputs voltages (there are 3)
Gavin
Check for a blown INTERNAL fuse in the Transformer housing !
Yukio YANO
Meat Plow
G'day all
Gavin
The rail on a 350 is 35 volts IIRC. Cant help otherwise
Arfa Daily
Yukio YANO
The internal thermal fuse is not a replaceable item. Also, the power
transformer is a designated safety item, so should not be substituted, if
the original approvals of the equipment are to be retained.
Arfa
GavinI
Yukio said:
GavinI wrote:-
Yukio YANO
Thanks for the suggestion Yukio.
If there is a fuse it's hidden well inside the transforme
unfortunately.
Gavi
Michael Black
If there is a fuse it's hidden well inside the transformer
unfortunately.
I don't think you are looking for an actual fuse. It would be a piece
of wire (or the whole primary winding) that has such high relative resistance
that if too much current is drawn, the winding opens. This is the same
principle as an actual standalone fuse, in that inside their casing
there is a small bit of wire that will open up if too much current is
put through it. But the transformers are designed so they'll open up
if too much current is drawn.
The result is not a "blown fuse" but an open winding, which is what
happened to you.
Of course, that leaves open the question of why the transformer opened,
so before replacing it, you'd want to be making sure nothing on
the secondary has gone bad to draw too much current.
As for voltages, you can at least get an idea by looking at the
electrolytic capacitor(s) in the power supply. The secondary will
go through some rectifier, likely a bridge but maybe some other
configuration, and then to some filter capacitors. Those (and they
are relatively big) will have a voltage rating marked on them, and
that rating will be higher than the transformer output voltage. How
much higher is why it only provides an idea.
Michael
Arfa Daily
resistance
happened to you.
Michael
It usually is a *proper* fuse in as much as it is an encapsulated component
with a temperature rating rather than a current rating. It's called a
"thermal fuse", and that is the reason that it is buried in the windings,
close to the transformer core, where you can't get at it. Many such
transformers have the legend " Thermal fuse fitted " stamped on them. Often,
the fuse element is actually wired across two terminal pins on the
transformer. One of the power input leads goes to one of the terminals,
whilst one end of the tranny primary winding goes to the other. A third pin
has the remaining winding connection. In these cases, a safety resistor or
convential wire ended fuse can be TEMPORARILY wired across the pins to which
the thermal fuse is connected, to allow the rest of the unit to be checked
for problems. It is however, very unusual for there to be any other fault,
particularly on Denons. Their transformers just go open for the hell of it.
I replace probably 5 or more a year.
As far as calculating winding voltages from smoothing cap ratings, it is a
valid technique, but a couple of "rules of thumb" need to be applied. You
should first take a value of about 2/3 or 3/4 of the cap voltage rating, so
if it's a 63v cap, a figure of say 45v. This then needs to be multiplied by
about 0.7 to get back to an RMS value for the winding voltage, because the
rectifier will produce a peak voltage from the RMS voltage, and the
smoothers will be rated to withstand this. That gets you back to 31.5v RMS.
Knock another couple off to allow for unloaded over-voltage, and you would
come up with a transformer winding of 30v RMS nominal, which would produce a
nominal unloaded DC rail of about 45v.
However, as I said before, you are unlikely to find a suitable multi-winding
tranny with the correct ratings, physical size and safety approvals ' off
the shelf ', unless that shelf is in a Denon component supplier's premises
Arfa
GavinI
Arfa said:
"Michael Black" [email protected] wrote in message
GavinI ([email protected]) writes:-
Yukio YANO Wrote:-
GavinI wrote:-
Yukio YANO-
unfortunately.
piece
resistance
same
happened to you.
opened,
Michael
component
windings,
Often,
pin
or
which
checked
fault,
it.
is a
You
rating, so
multiplied by
the
RMS.
would
produce a
multi-winding
off
premises
Arfa
Thanks for your comments & v.good advice Michael & Arfa
I have worked out the supplies for the control electronics (around 15
20V) & the PA section (80 - 100V centre tapped). The 3rd o/p is provin
to be a little more problematic. It doesn't appear to be rectified
only measures 15ohms accross the cct side ie - with the transformer
disconnected. It appears to supply stuff around the vacuum fluoro
display. I'm guessing the display needs a fairly high voltage, or it's
stepped up somewhere (perhaps this is the reason I'm measuring the
15ohms; ie accross a coil/transformer winding?).
I appreciate now that it will be hard to find an equiv. as you've said
Arfa.
Gavin
Arfa Daily
I have worked out the supplies for the control electronics (around 15 -
20V) & the PA section (80 - 100V centre tapped). The 3rd o/p is proving
to be a little more problematic. It doesn't appear to be rectified &
Arfa.
Gavin
The VFD requires two supplies. The main one is in the region of negative 29
( -29v ) and is usually derived either via a seperate regulator from the
main negative rail or, more commonly, from a voltage multiplier fed from one
of the transformer general windings. The second supply is approx 3v AC for
the VFD filament. This is almost exclusively fed from a separate winding on
the transformer, the reason being that it is 'floated' on the -29v DC, to
reduce internal inter-electrode stress. I suspect that this is your third
winding, and the reason that it has such a 'high' resistance.
Arfa
