Hi Guys,
I've been reading about someone with a similar problem on this forum.
The Dishwasher won't power up at all, after removing the main control board I noticed a resistor with the shell burnt, after removing and testing it found it was open,
I wasn't sure of the value as the shell was burnt but could make out the first three bands- brown, black, black the last two bands were either black and white or gold and white, I replaced the resistor with a 10ohm, when I tried the board on the bench got various voltages as before but when installed into diswasher it poped. Upon inspection found the tny264 chip had blown and also found some marks near a component marked 67 not sure if that was caused by the tny264 as it's in the same vicinity on the board
Please can someone advise
A, if the resistor I replaced was likely to be 10 ohm?
B, if it never poped on bench what else can be causing it when installed?
C,Is it worth replacing the tny264?
D,What is the component marked 67 and how do you test it?
Sorry struggling to upload the jpeg photos any tips would be appreciated.
Thanks in advance for the support.
