BPSK and QPSK have identical BER curve ?
Davy
Hi all,
I have build a simulation system to test my Error Correcting Code.
And now I add modulation/demodulation module.
When I apply BPSK and QPSK to system, I found their BER versus SNR
curve almost identical, is it right in theory?
My code rate is 0.9, code length >10000.
BTW, I found BPSK and QPSK have identical uncoded BER versus SNR curve,
is above similar?
Any suggestions will be appreciated!
Best regards,
Davy
O
Oli Filth
Davy said the following on 05/03/2006 11:55:
Hi all,
is above similar?
QPSK can be regarded as a pair of orthogonal BPSK systems, i.e. the real
component is one BPSK system, the imaginary component is the second BPSK
system. Because they are orthogonal, they don't interfere (to a good
approximation), hence the BER curves are largely equivalent.
Davy
Hi Oli Filth,
Oh, I see. Thanks!
Best regards,
Davy
Mike Yarwood
If you plot Eb/No vs probability of bit error.
But you expect to see same PeBit for QPSK when the SNR is 3.01 dB higher
than for BPSK because, at the same symbol rate, they occupy the same
bandwidth and the signal energy needs to be twice as big for QPSK to have
the same energy per bit as BPSK.
Best of luck - Mike
The probability of bit error of both the systems are equal
with channel coding and without channel coding.
If you derive analytical expression for BER with channel coding, both
have the same expression.
Best Regards,
-SaiRamesh.
