Bridge Rectifier help required please.
sme
Hello Group,
I have just purchased a bridge rectifier MP256 (Rectron).
It flat with four pins one pin is next to a flattened corner which I presume
is the positive ac in.
Other than this I have no idea what the other pins are as they are not
marked.
Any help would be much appreciated.
TIA
Steve
sme
All I managed to work it out!
Thanks all the same!
Tweetldee
sme said:
Hello Group,
marked.
TIA
Steve
I don't have a reference for that exact part number, but generally
speaking, a flat SIP bridge rectifier will have the two middle pins for the
AC input, the pin adjacent to the marked end (whether the marking be a dot,
a chamfer, or a flat) is the (+) output, and the other end is the (-)
output.
Cheers!!
Dave M
MasonDG44 at comcast dot net (Just subsitute the appropriate characters in
the address)
Never take a laxative and a sleeping pill at the same time!!
K
Ken Moffett
sme said:
Hello Group,
marked.
TIA
Steve
http://www.mouser.com/catalog/619/274.pdf
Right column, near the bottom under, 25Amp/600V: 583-MP256
If I recall correctly the flat is the (+) pin. (-) is the pin diagonally
accross the square from the flat. The other two are the AC inputs.
All I did was Google: MP256 Rectron
