Bridge Rectifier not giving full-wave rectification
lsiu
I have a circuit like this
(http://lsiu.dyndns.org/static/circuits/supply01.png). When I tried it out
on the scope with a 60Hz sine wave function generator with output 10 Vpp, I
only get half-wave rectification reading from my oscilloscope. The
connection from the function generator goes to the two ACs of the rectifier,
and the scope connects to the + and - of the rectifier. Any Ideas why I
don't get a full-wave rectification?
I am using this rectifier
(http://www.rectron.com/data_sheets/rs201l-rs207l.pdf)
Thanks for your help.
Leonard
John Woodgate
One of which is ground....
.....one of the connections being ground.
See above. Draw the grounds on your schematic.
BFoelsch
I can make a good guess-
I would guess that your function generator and your oscilloscope both have
their common terminals grounded to the case, which is in turn connected to
the earth ground through the power cord. Effectively, the black terminal on
the function generator is connected to the black terminal on the
oscilloscope. That would bypass one of the diodes in the bridge giving an
unexpected effect.
Leon Heller
lsiu said:
Something to do with your grounding arrangement?
Leon
F
Frank Bemelman
lsiu said:
Didn't you blew a fuse or something, with this experiment,
the other day?
Perhaps you blew one of the diodes in the bridge, and
need a new bridge.
Baphomet
lsiu said:
Leonard
You're lucky you didn't blow anything...or maybe you did. You should be
using an isolation transformer when working directly from the line. Absent
that, use ground cheaters on all of your measuring equipment.
John Fields
I don't think he meant that he had it hooked up to the mains, but rather
that the output of his function generator was hooked to the AC side of
the bridge and that he was trying to look at the output of the bridge
with his scope. Such being the case, he would get the waveform he saw
if the ground sides of the scope and function generator were common.
Baphomet
You may be right John. When I looked at his schematic, I saw the outlet
symbol, cringed, and posted.
