Building prototype gadget - would appreciate advice :)
Seth
May 24, 2013
5
Hi all,
I'm new to this forum and microprocessors in general. I'm hoping to build a gadget which can transfer small amounts of information via infrared. However, I only know a little about electronics and have no clue about microprocessors and how they are different to normal processors.
I need a program to execute one program which simultaneously transmits and receives a few kB of data (read from flash memory) from another device of the same nature. So I'm asking what microprocessor and IR transmitter/receiver would be suitable? Bear in mind that I'm working on a budget so the cheapest and most low-power processor is best.
I have experience programming Arduinos but I have no idea how to program microprocessors. Is there a simulation so I can test without slowing down prototype production?
Seth
An Arduino is a microcontroller with a few extra bits.
If you've programmed one, you've programmed a microcontroller.
A microprocessor is technically the thing you find inside a PC. They typically need a lot more to make them useful (RAM, ROM, periperal support, etc.)
You probably want a microcontroller.
Seth
May 24, 2013
5
Ah, I knew that I wanted a microprocessor as part of an embedded system, but I'm not sure which specific microprocessor to get.
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
Broadly, microcontrollers are single-chip devices (at least nowadays they are), with all or most resources in a single device. This means no expandability, limited RAM and ROM, a variety of peripherals built-in, and usually a user interface consisting of buttons and a small display or indicators. Microprocessors are just the core of a larger system that typically includes external expandable RAM, modular peripherals of all kinds, generally much higher speed and power consumption, large storage devices, and usually a versatile user interface.
Your best approach is to figure out what you need in terms of high-level language support, power (speed and resources such as RAM and ROM), and peripherals. From your brief description of what you want to do, I would say that a microcontroller is most appropriate. If you give a more detailed description of your project we will be able to be more specific.
Seth
May 24, 2013
5
Thank you for your time and patience in helping me, I understand physics extremely well but am fairly new to electronic devices :)
The code in the device will allow data to be sent to a similar device via IR, and data received simultaneously. This data should be able to be modified by connecting the gadget to a computer via mini USB port. Also, whilst transmitting, some LED lights will act as an indicator (ready, transmitting, complete). A button on the outside of the gadget is requires to start the script and loop it for a few seconds.
Said data is very light and should not be more than a few KB, but it does need to be edited so the memory will have to be rewritable. I am planning to code an interface so data can be edited whilst connected to computer via mini USB, I think C should be sufficient but if you have any suggestions as to which language is easiest to write an IR protocol and interface for than I would be more than happy. Data received via IR also has to be written to flash memory and be erasable. I estimate total data at a couple of MB depending on the size of the interface.
As for power, you can tell that this process isn't very intensive. I would say that power saving is the better option and also I am taking price into consideration as I am planning to make a few of these.
Thank you very much :)
If it's going to connect to a USB port, you may as well use the computer's processor to do all the hard work.
You could probably pull the guts out of a USB to parallel cable and then bit-bang it to flash LEDs connected to the data pins.
Seth
May 24, 2013
5
Yeah, but the device has to be portable so a microcontroller is still needed. Connection to computer is only to store received information and edit data.
