buying a low cost oscilloscope for tinkering
s
any pointers for buying a low cost oscilloscope for hobbyist tinkering
of tv/vcr etc
like what freq/voltage ranges generally to look out for.
are the pc based or handheld LCD ones any good?
thanks
s
N
NSM
| of tv/vcr etc
eBay
Prices are low. Get the best you can afford.
| thanks
are the pc based ones any good?
Not bad - useful for some things.
are the handheld LCD ones any good?
Very good but pricey.
Charles Schuler
of tv/vcr etc
thanks
Gee, oscilloscopes are like cars ... you will get hundreds of opinions ...
all valid perhaps but all focused on user bias.
If you have never owned one before, start very basic and start used. For
example, there are flea markets called "hamfests" where you can sometimes
pick one up from someone local who cannot screw you as you "know where he
lives." Ebay is rife with them but be wary!
Stay away from digital scopes and high price tags until you get your feet
wet with an older analog scope.
Bandwidth of 50MHz should be good, dual trace, 20 mV sensitivity. Tektronix
is the best brand name out there, by the way.
Jim Yanik
... all valid perhaps but all focused on user bias.
For example, there are flea markets called "hamfests" where you can
sometimes pick one up from someone local who cannot screw you as you
"know where he lives." Ebay is rife with them but be wary!
feet wet with an older analog scope.
Tektronix is the best brand name out there, by the way.
One of the least expensive used TEK scopes would be the T932/35,35 MHz
BW,not having any TEK-made ICs in it,and easily serviceable.
One of the simplest scopes TEK ever made.
Or the TEK 442,a rack-mount version of the T935.
(T932=single channel vertical,T935=2 chan.)
Next on my short list would be the TEK 2213/15/35 series.(incl. "A"
versions)
(not 2230/32 digital models)
Sam Goldwasser
versions)
I picked up a 2213 on eBay not long ago for under $100. Only problem was
a missing holdoff knob.
--- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
+Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
| Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
Note: These links are hopefully temporary until we can sort out the excessive
traffic on Repairfaq.org.
Important: Anything sent to the email address in the message header above is
ignored unless my full name is included in the subject line. Or, you can
contact me via the Feedback Form in the FAQs.
Jim Yanik
was a missing holdoff knob.
Keep track of the focus string resistors;they have a habit of increasing in
value until they open. Use 1/2w carbon composition to replace instead of
carbon film types(TEK's recommended mod)
