CAD Software Development
Stephan Rose
Hey all!!
Couple years ago I started development on my own EDA Package, and at
that time I finished a good portion of the schematic part.
Unfortunately, life got in the way and I had to put the project to
rest for a while.
Well in the meantime, life got out of the way again and I have resumed
on this project. It is my goal to create an easy to use, affordable,
and powerful complete EDA package including libraries, schematic, and
pcb all together under 1 roof.
In it's current state, the schematic library editor is fully
functional as is the schematic editor.
Netlist generator works as well, though it currently only outputs
netlists in Tango format which I used to test my generator. Since we
still use Tango at my father's company, I had lots of designs to test
my generated netlists at. Success rate was 100% =)
The schematic error checker is a little overzealous right now, but
it's there. I will do more work on it at a later point in time unless
any serious issues arise with it.
With the schematic side primarily up and running I am now working on
getting the basics for the pattern editor working and then get the pcb
side running. You will actually see a test document when you start the
app that tests my pads for the pattern editor. =)
What I am looking for right now is input, suggestions, feedback, bug
reports, etc. Any input, both good and bad is appreciated.
So if anyone feels like playing around with this, I would love to hear
your comments!!
The application can be download here:
http://www.somrek.net/iEdaBuild0.rar
Just extract the archive anywhere you like, run iEda.exe in the bin
directory to start the app.
For those who may not have winrar to extract the rar archive:
http://www.rarlabs.com
The application also requires the .Net Framework 2.0 which can be
found at the following location:
http://www.microsoft.com/downloads/...cb-4362-4b0d-8edd-aab15c5e04f5&displaylang=en
It is a one-time install only.
The latest version of DirectX is also required, though not
reccomended. If available, and if the video card supports DirectX9,
the application uses a hardware accelerated renderer for drawing. If
not, it falls back to standard software GDI. The latest version of
DirectX 9 can be obtained here:
http://www.microsoft.com/downloads/...38-DB71-4C1B-BC6A-9B6652CD92A3&displaylang=en
If you have any questions, feel free to e-mail me at
[email protected] or just post a reply, I will be happy
to assist.
Thanks in advance for anyone who wants to check this out =)
Stephan
2003 Yamaha R6
kimi no koto omoidasu hi
nante nai no wa
kimi no koto wasureta toki ga nai kara
Stephan Rose
I don't get any files extracted. Zilch.
Weird, I just downloaded the file from my server to test and
everything extracted just fine...should get the following directory
structure extracted:
iEDA/bin/iEDA.exe
iEDA/bin/Plugin.dll
iEDA/bmp/arc.png
iEDA/bmp/arrow.png
iEDA/bmp/attribute.png
iEDA/bmp/circle.png
iEDA/bmp/component.png
iEDA/bmp/junction.png
iEDA/bmp/line.png
iEDA/bmp/pin.png
iEDA/bmp/polygon.png
iEDA/bmp/rectangle.png
iEDA/bmp/reference.png
iEDA/bmp/reroute.png
iEDA/bmp/text.png
iEDA/bmp/zoom.png
iEDA/Plugins/Libraries.dll
iEDA/Plugins/Schematic.dll
I put a zip file up for ya instead. Maybe that will work better =)
http://www.somrek.net/iEdaBuild0.zip
Stephan
2003 Yamaha R6
nante nai no wa
rest for a while.
Have you seen gschem?
http://www.geda.seul.org/tools/gschem/index.html
(uses 'pcb' to handle circuit layout)
Or KiCad?
http://iut-tice.ujf-grenoble.fr/kicad/
They are win32 free aswell.
Oh I know other's exist but I am so far along now that there is no way
I am going to stop. =)
At least make your version unix portable. Or your software will be obsoleted
by the next fad ms comes up with.
Stephan Rose
On 03 Jul 2006 12:42:28 GMT,
Erm you are telling this to a guy who has been writing windows
software for oh I don't know...almost 10 years now? =)
But yes, it actually is sort of portable to unix. The code is purely
..Net based making zero use of any win32 api calls with the exception
of my debug profiler class for timing code. But obviously that timing
class is not important for operation and would be easily ported
anyway.
There is a .Net Framework implementation available for unix called
Mono. I have never actually used it but it appears that they are doing
quite good. The currently release does not support the .Net 2.0 specs
yet but an upcoming release should making a port possible.
The only potential issue would be the DirectX rendering pipeline which
is optional anyway. But without it, I would also need to ditch the
Microsoft.DirectX.Vector classes I use for rendering purposes to save
myself time in writing my own. Not really a major issue.
Stephan
2003 Yamaha R6
nante nai no wa
Stephan Rose
On the other hand, let me ask you this.
How important is unix portability? And I don't mean just your personal
view on this. I am still at a point in time where I could say ok fine,
I will go to C++ instead and disconnect the then required win32
portion. Would take a little bit of time but not that terribly much.
If it's worth it, I will do it. But I don't even remotely have the
ability to judge that from where I am sitting.
Note though that I am looking for professional reasons, not
anti-microsoft statements.
Stephan
2003 Yamaha R6
nante nai no wa
Unix systems are on the whole more stable and straightforward. In practice
this means less problems with network attacks and no virus problems.
I have machines that only reboots when there's a trouble with power.
It also makes it a lot easier to juggle around with cpu power, discs, and
networks as the needs arises. In short superior flexibility with resources.
API's tend to be more stable meaning investments in knowledge and code can
be used for longer time. And no BSA to chase you should you missed some
license issue.
More on why..
http://www.catb.org/esr/writings/taoup/html/
Stephan Rose
On 03 Jul 2006 19:19:13 GMT,
license issue.
Honestly...I have to disagree with some of that. The only time my
win2k3 server has restarted is when I had a power outage. Other than
that I have had 100% reliability and uptime.
Every single XP system I own, and I do have multiple, all are stable,
adware free and virus free.
In the hands of an inexperienced user, both a unix or windows system
can go unstable and go to crap. In the hands of an experienced user,
either can be just as good and it matters more towards the users needs
/ preferences which to use.
For me a reason to develop for unix would go more along the lines of
"90% of my userbase resides there" or some other statement to that
effect =)
Stephan
2003 Yamaha R6
nante nai no wa
DJ Delorie
Mac OS/X is Unix-based. We discovered (pleasant surprise) that the
"Unix" PCB (pcb.sourceforge.net) builds as-is under OS/X using their
OpenMotif library. No porting required, poof! Mac OS/X support.
Plus, of course, all those Linux distros are gaining market share too.
Joel Kolstad
I agree with Stephan here; WinXP is perfectly stable so long as you don't load
a bunch of crap onto it -- which is the same thing that's true of ANY OS,
Linux, the Mac OS, etc. I would, however, agree that WinXP comes somewhat
less secured "out of the box" than many Linux distributions and the Mac OS
does these days.
From an end-user point of view, Linux is still *considerably* more difficult
to install software on than Windows is -- it certainly doesn't pass the
"grandma" test.
