Cadence Allegro initiation
Hi all,
I try to understand the complete process to bring a design to a
physical PCB with the Cadence Suite. All the component in the release
PSD 15.1 give me a really hard time. I have difficulty to understand
the logic sequence between design and the PCB. I did my schematic with
Capture CIS. What I must do after, create a netlist? When I should
provide the board outline and with which software, Spectra Quest???
What is the difference between SpectraQuest, Spectra, PCB Designer,
etc???
Can you provide me a little help to clarify a few things or do you know
good tutorial to start. It's impossible to start with the cadence
litterature.
Fred
Charlie Edmondson
Hi all,
etc???
litterature.
Fred
Hi Fred,
Well, I would start with either going through the chapter 14 of the CIS
user's guide for the beginnings of using Allegro editor with CIS, and
then look at the tutorials for Allegro editor. You are talking about a
subject that people take a few $1000 classes to learn the basics on,
much less get good at.
You set up the board outline and develop all your PCB libraries in
Allegro Editor. SpecctraQuest is now Allegro SI (signal integrity)
which should give you a clue that it does signal integrity analysis.
Specctra is the industry standard auto-router. PCB Designer is a
combination of Allegro Editor with a front end, usually Concept (Allegro
Design Entry HDL)
The Cadence website has links to internet training, but it is almost as
expensive as the live classes.
Charlie
Jim Thompson
Hi Fred,
Because Cadence products are so-o-o-o-o intuitive ?:)
Design Entry HDL)
Charlie
...Jim Thompson
Is there other good and easier tools to learn than allegro. I don't
need the complete simulation features include in Allegro.
