Cadstar Help - how to merge two different designs into one PCB?
minus3db
Hi all, I am really hoping that a Cadstar guru out there can help me
with this problem.
I have two different schematics, each with their own unique PCB. I
want to combine the two existing PCB layouts into a single new PCB
layout.
Here's the problem: there are common component designators between both
schematics. For example, there is a diode D1 in schematic/PCB #1, and
a diode D1 also in schematic/PCB #2.
This is the case for several hundred component designators on both
boards.
I've tried to combine the two schematics together, which changes the
component designators for schematic #2. As a result, when I try to
stitch the two PCB layouts together, I'm unable to generate an ECO
update, since the component designators no longer match.
Has anybody had this problem before? I'd appreciate *any* feedback
that might help me solve this problem.
Thanks in advance,
minus3db
James Beck
with this problem.
layout.
boards.
Thanks in advance,
minus3db
Maybe do it with a Gerber editor, just paste them both into a common
file?
Jim
Geo
file?
But surely he can't keep duplicate references on the final board - how will the
assemblers know which R1 is which?
Geo
Anton Erasmus
One would asume that it is two separate PCBs, that is just combined to
make manufacturing cheaper.
Regards
Anton Erasmus
Similar threads
