Camera flash style circuit - need a little guidance
tabs1
Oct 15, 2010
Hi guys,
I've been looking for a knowledgeable electronics forum for a while, where I can go to ask the stupid questions that I usually get stuck on. I've stumbled across your site and think that it might be the right place for me. I hope you don't mind me jumping right in, but I'm trying to put together a fairly simple circuit and need some guidance;
I have a number of 1W LED spots, running at either 350mA or 700mA depending on which transformer I use (I have two). I'd like to wire these up so that they work like a camera flash - I.E once they are triggered they'll produce a couple of seconds worth of light, before fading to off. Quantity of LEDs is flexible, up to a max of four. Basically whatever works. The whole thing will be UK mains powered (230V @ 50Hz). The transformers I have step down to 24V.
I *think* that I want to be using capacitors, but am unsure of the quantity, type or position in the circuit. I'd really appreciate any help that you could give me to get this sorted!
Tim
Hero999
Oct 28, 2007
2,433
To be honest I'm still not sure what you want help with.
Do you already have a circuit to light the LEDs but just need a timer?
A 555 timer will do, the schematic is on the datasheet which can be found using your favourite search engine. :D
As far as a circuit to light the LEDs is concerned, a constant current source will do; this can be made using an LM317. The LEDs should be able to withstand higher currents for short periods of time so putting 1.5A through an LED rated to 0.7A for a second shouldn't do it any harm.
