Can a commutator be made to produce dc current turning in both directions?
Minder
Apr 24, 2015
3,560
It does, if referring to a DC motor/generator.
If wishing to maintain a certain polarity regardless of direction, then a simple bridge rectifier on the output will do it.
M.
daberbaber
Feb 2, 2012
18
Minder's comment answers your question and gives a great tip for maintaining polarity of the voltage coming from the commutator. And the field is supplied by a PM permanent magnet. In a car system however and in many other motors, the field is supplied by an outside source and this will complicate any attempts to use a motor for a generator/alternator.
James Robieson
Oct 16, 2016
3
Ok daberbaber
Thank you, that clears up a lot things.
