Can a subwoofer be hooked up in Series with speakers?
Raventy
Hey guys,
I have an arcade machine which inside has 4 speakers and a subwoofer.
Durring the moving of the machine, the subwoofer broke loose along with
its wires and I cant exactly figure out where it hooked into. Can
subwoofers be hooked in series or parallel with speakers or do they
need some special connection for them?
K
Kalman Rubinson
Hey guys,
Depends. If it has its own filter/crossover, it can probably be put
in parallel (not series). Otherwise, not.
Kal
N
NSM
Hey guys,
Dual coil?
N
Raventy
Kal- How do I tell if it has its own filter/crossover?
N- What is Dual Coil?
K
Kalman Rubinson
You look for it or for printing on the outside which indicates it.
If you do not know what/how, find a local who does.
Kal
Raventy
Well it only has 2 terminals on it so I guess its not dual coil. The
label on it is almost all gone.. all I can see is that it says its an
8ohn subwoofer. Will hooking this in parallel hurt anything even if its
not designed to be in parallel?
N
NSM
Don't do it. Better to do without. Wait until you find an expert or a
manual.
N
Dave Plowman (News)
It depends on the existing speakers and amp. If the existing speakers are
8 ohms and the amp says it can drive 4 ohm ones, then two 8 ohm speakers
in parallel give 4 ohms. Approximately. Since no two different speakers
are uniform 4 ohms across their range.
However, the normal way to drive a sub is to take a feed from both left
and right via a pair of buffer amps and parallel them. Then have a
separate low pass power amp for the sub to allow it to be adjusted to suit
room acoustics and your main speakers, etc.
