casi rusco
N
neil
My company took over a account from a big security chain. One of the
building on this campus has a Micro 5 PX with 2 CK8RP and STI boards
installed. Part of the take over was that we upgrade the system to
Secure Perfect to 6.0. After the upgrade the security office started
receiving hundreds of alarms from this building on all reader doors.
Two techs were sent out to go thru all inputs that are connected to the
STI boards. We could not find anything wrong accept poor installation
practise. Called GE tech support and the tech I spoke to told me since
we flashed the Micro with 3x app. code version 6.002 that we should
find out what firmware version the STI board are. The company I work
for order the 9 pin cable needed to connect to the CK8RP board. When I
connect laptop to the CK8RP using the Flashtool program, the program
could not see the STI boards. So I tried MCUTIL, this did'nt work. I
called GE tech support and the tech I spoke to was not really any help.
So I was wondering If any body out there that has work with these
boards could give me some help. Thanks neil
Silicon Sam
Actually, the 9 pin cable hooks to the Power/Comm board. The 8RP is
the reader interface board. It only has connections for the 8 readers,
nothing else
Not familiar with the STI boards, since I have only used the 20DI
boards. 20 input board basically.
N
neil
thanks Sam, the CK8RP is design for take over of Card Key access
control system using the readers and twisted pair wire that runs from
the Card Key controller to door modules. The CK8RP board has 8 reader
ports and one 9 pin connector built on the board and this is for
flashing the STI boards out in the field. In the Flashtool program
under File theres a selection for flashing STI boards.The STI boards
are similar to the WIU-4 boards used to connect HID readers to the 8RP
boards thanks neil
Andrew Buchanan
Just so I know, what readers are you using? I guess they're not Casi, as
casi prox readers will supervise the door devices when using an 8RP so all
you need to run is a 2pr/22. Since your familiar with the software, you
probably know that already.
Andrew
N
neil
thanks Andrew, the reader that are connected to the STI boards are HID
PROX. On the board there are dip switch setting for reader format,
supervise, non-supervise and address. Also if you make the board
supervise there are 4 extra DI inputs. In the installation instruction
all is requied is 22/2 twisted pair non-shield wire from the Micro to
the STI boards. The STI Boards have to be flash with a firmware ver.
15 or 17 depending on the manufacture date of the CK8RP thru the 9 pin
connector built on board. I have not figured the problem out yet. I
order new Comm/Power and CPU boards. If you can help me in any way, I
would greatly appreciate it. thanks neil
