I
ina
- Jan 1, 1970
- 0
I need to design a low power transmitter that will transmit five
different signals to a receiver that is at most five feet away. I'm
doing the design for a client who insists on using RF instead of IR.
I'm designing the transmitter first and have decided to use ASK
modulation at a frequency between 20Mhz-30Mhz. The frequency is not
yet finalized. I'll have to research which freq is legal to use. I was
thinking of using a microcontroller to encode the five signals and
generate the carrier signal. I could create a square wave at an output
port and filter out a higher harmonic to reach the CB band but im not
sure if this is a sound idea. A RISC 8-bit controller could generate
an 8Mhz square wave and thus a harmonic at 24Mhz. The weak signal
strength of the harmonic may not be an issue since the max. distance
between the receiver and transmitter is only 5ft.
Does anybody think my idea is feasible? I'm new to RF design. Thanks.
