choosing a suitable transistor
randomname
I need a transistor (used for switching, from 6v supply) that will
power a maximum of 400mA. For now I'm using a TIP31 but this is
blatant overkill.
Will this transistor work instead: MPS3704
Also, which resister do I need to use?
So I don't ever have to ask again, what's an easy way to compute
transistor specs, and resistor values?
-sam
John Popelish
blatant overkill.
For on off switching, the maximum collector current spec on data
sheets is a poor guide, except that it is way too high.
http://www.fairchildsemi.com/ds/TI/TIP31C.pdf#search="tip31"
Lists the maximum DC collector current at 3 amps.
For low voltage drop switching I usually look for a transistor with a
gain at the load current that is at least half the peak gain shown on
the DC current gain curve, at some low DC collector voltage.
The above data sheet indicates that this half peak gain current (with
4 volts collector to emitter, on page 2) is about 1.5 amps.
I also check the saturation voltage curves for a forced gain of 10 and
make sure that the maximum voltage drop is below about 200 mV. This
is about 1.2 amps for TIP31. So, though it has a higher current
capability than you need, it is not grossly oversize, unless fast
switching is also important, because the over sized die has more
capacitance and stored charge than necessary.
Taking a look at 2N4401,
http://www.fairchildsemi.com/ds/2N/2N4401.pdf#search="2n4401"
with a maximum collector current rating of 800 mA,
But the gain curve falls to half its peak value at about 450 mA (with
5 volts collector to emitter).
Checking the saturation voltage, it is about 300 mA for a saturation
voltage of .2 V and a forced gain of 10 (with 30 mA of base current).
If you can spare this much base current, this transistor is just about
as small as you can go for a saturated load of 400 mA, with a
reasonable base drive and saturation voltage.
A really fine saturated switch for this sort of current would be one
of the high gain, low saturation voltage devices from Zetex. You
haven't mentioned the off state voltage the transistor must withstand,
but assuming 40 volts, take a look at ZTX1051A (Digikey sells these,
but they cost as much as the TIP31).
http://www.zetex.com/3.0/pdf/ZTX1051A.pdf
Half peak current gain is about 5 amps and the gain is still over 200.
The saturation voltage at 400 mA is only about .05 volts with a
forced gain of 100 (4 mA of base current). All this in a tiny to-92
package.
I love this line.
randomname
package.
I love this line.
I'm hoping I can use the 2N4401, as it's a real cheapy. My base
current will be 200mA, it's coming from a 555 timer.
I read at some website
[http://www.kpsec.freeuk.com/trancirc.htm]
that a transistor is fine if:
1) Ic > your load current (this one has 600mA Ic, check.)
2) hFE > 5 * Lc/Supply Current (5 * 400/200 = 10)
Is this sound advice?
Thanks a lot
-sam
John Popelish
If you limit the base current to 40 mA with a suitable resistor, it
should do fine.
Since the Ic max specs are often exaggerated, I would have said that
Ic max should be 3 or more times the loads current, for good
saturation voltage. The 2N4401 is good here, with an IC max of 4
times your 200 mA load current.
That is 5*Load current/chip output current. This just says that the
minimum (linear, not saturated) gain is at least 5 times more than
needed to boost the maximum chip output current up to the load
current. This allows the gain to fall to 20 % of the linear minimum
when the transistor saturates, to get a low saturation on state
voltage drop.
Pretty reasonable.
John Popelish said:
should do fine.
Are the manufactors cheating on a regular basis ..?
Chris
John Popelish said:
should do fine.
Manufacturers don't cheat, they just tell the truth in different ways.
As an example, look at the data sheet for the ZTX1051 above. Under the
Absolute Maximum ratings, it lists maximum power dissipation as 1 watt
at 25C.
That's the highest claimed AbsMax Pd for a TO92 I've seen. While I
believe in sunshine just like everyone else, I also know a TO92 package
is gonna be hot as a $3 pistol at the firing range if it goes above a
half watt without a heat sink, and you realistically shouldn't put more
than 1/4W steady state on a transistor in that package without a heat
sink at a normal range of ambient temperatures without forced air if
you want a reliable circuit.
But I'm sure the manufacturer's claim is definitely true. If you keep
the package surface temp at 25C, it will handle 1 watt of power. To do
that, you'll have to immerse the device in flowing ultra-low
conductivity deionized water, but there it is.
Theta(Junction-to-Case) of a TO92 package is about 83 degrees C per
watt. Your TO92 immersed in 25C deionized water will have a junction
temp of (25C + 1.0W * 83C/W) = 108C, which is fine. Not even close to
being realistic, but fine. Of course, Theta(Junction-to-Ambient) of a
TO92 is 200C/W. And most TO92 heat sinks don't do much of anything
anyway -- the mating surface of the transistor is too small, and is
plastic instead of metal.
Mr. Popelish's choice for the OP is best (I gotta get me some of those
on my next DigiKey order). With a Vce of 50mV, it'll barely get warm
at 400mA. Assuming I had the base current available, though, I might
have gone with the TIP31. It's a gumball part (low cost multiple
sources), it can easily handle the current, and the Theta(JA) of a
TO220 is only 60C/W or so.
Overkill is a rather strong word, especially if you're not building
hundreds or thousands of 'em. If you avoid the obvious things that
decrease circuit reliability, you can usually get it done and go home
on time without having to worry about fixing it. I'd call it
overbuilding or bulletproofing.
Cheers
Chris
John Popelish
No. It is just not practical to make use of transistors at the
maximum possible current they can survive. That spec is a limit to be
avoided, a boundary not to be crossed.
You also should not operate 1 watt resistors at 1 watt, if you expect
reliability and stability from them.
Jonathan Kirwan
blatant overkill.
Your last paragraph begs something else, entirely. At least, it
appears to ask for you to be "taught to fish, rather than be given a
fish to eat," so to speak.
Understanding how to set part values and otherwise using transistors
for switching (and just staying within the domain of bipolar
transistors [BJT's] here), involves knowing more than what you suggest
above. It means understanding a little about how they work and
knowing at least some of the many possible topologies -- hopefully, in
fact, being able to arrive at some of them on your own imagination, in
fact.
So rather than answer your more immediate questions, I'm going to
point out some directions to look.
BJT's are usually "looked at" as inverting. When you use one BJT as a
switch and actively drive it, the low-voltage drop of its emitter to
collector is usually a condition caused by creating a significant (in
the neighborhood of 0.8V) voltage difference between its base and
emitter. So "pulling down" the base of a PNP tends to "pull up" its
collector; or "pulling up" the base of an NPN tends to "pull down" its
collector. However, there are other cases -- such as "pulling down"
on its emitter (with base tied at some V) also pulling down the
collector.
Here are some non-inverting voltage translation circuits (which amount
to switches):
: Vcc2
: Vcc1 |
: \ Vcc1 R5 / Vcc2
: / R2 | \ |
: | R3 |<e Q2 | |<e Q4
: +----/\/\------| PNP +-------| PNP
: | |\c | |\c
: | | |/c Q3 |
: R1 |/c Q1 | CONTROL >----| NPN |
: CONTROL >---/\/\-----| NPN \ |>e \
: |>e / LOAD | / LOAD
: | | R4 / |
: gnd gnd \ gnd
: Vcc4 /
: \ gnd
: / LOAD
: / Vcc3
: Vbase | \ Vcc3
: | | / R9 |
: | R12 |/c Q7 \ |
: '---/\/\-----| NPN / |
: |>e | |
: | | |<e Q6
: | +--------| PNP
: | | |\c
: CONTROL >--' | |
: R10 / |
: | / LOAD
: R8 |/c Q5 |
: CONTROL >---/\/\-----| NPN gnd
: |>e
: gnd
If you learn to understand these reasonably well, you will pretty much
be able to do your own calculations of resistor values.
BJT's also include some effective capacitance between base and
collector and base and emitter. These values are often roughly in the
area of 10pF, or so, for general purpose BJTs. How these affect speed
depends on the resistor values (you can often use lower values to help
out on speed, at the expense of operating current), but in most cases
where one millisecond is considered "fast enough," you won't need to
worry about that aspect. If very short switching times are required,
you will need to worry about this capacitance and provide a means to
overwhelm it.
Jon
Jamie
blatant overkill.
-sam
Hmm, if you saturate a 2n2222 that will work.
