Circular saw won't ground, safe?
Tim Zimmer
Is it safe to operate an all alloy housing circular saw. My
15-year old industrial saw is reliable but the only thing aging
is the cord. The cord's insulation is cracking and deteriorating.
Last I'd check the ground wire is open but hidden from view.
What would be the hazards if I continue to use it?
F
Franz Fripplfrappl
The ground protects YOU. Replace the cord and connect the ground. The
bottom line is: How many more years do you wish to do woodworking?
N
Nog
Only death.
Open the case and replace the entire cord. Then you can use it for another
15 years.
Andy Dingley
We'll all laugh at your funeral when they bury you in a cardboard box
for being a skinflint.
It's a fecking power cable. Coupel of bucks most, even for good quality
cable, and a few minutes job to fix. I have sympathy for people who get
hurt from damaged cables by accident (this is why workshop tools should
be tested and inspected, not just ignored) but to _know_ that it's a bad
cable and to carry on using it is just pikey.
spudnuty
It is quite an easy matter to replace the power cord and ground but
even with a grounded device you're depending on a chain of secure
grounds to keep your tool safe. I would also obtain a GFCI pigtail and
only run your power tools from that. They're required on all jobsites
I've been on and all the electrocutions I've studied have been from
workmen bypassing them.
Richard
toller
Richard
A couple years ago I moved an outlet by putting a hand on each side,
contacting the hot with one and the neutral with the other. (I thought "the
other guy" had opened the breaker) I was rather surprised to be alive and
unhurt afterwards. I did some research and found out it is almost
impossible to get a lethal shock from 120v under normal circumstances.
Virtually all the electrocutions on record have been from 4000v or higher.
Accordingly, I am wondering about those fatal accidents you have studied.
If my understanding is incorrect, I certainly want to get it adjusted. (no,
I do not treat 120v casually; "almost impossible" means it is possible...)
Dr. Anton T. Squeegee
You would be risking a fatal electrical shock, should the saw
develop an internal insulation fault (as it very well could if it's that
old).
Replace the cord completely. If you lack the requisite skill
and/or tools to do so properly, you should take the unit to a
professional repair shop. Any place that repairs power tools should be
able to handle it.
Dr. Anton T. Squeegee, Director, Dutch Surrealist Plumbing Institute.
(Known to some as Bruce Lane, ARS KC7GR,
kyrrin (a/t) bluefeathertech[d=o=t]calm -- www.bluefeathertech.com
"If Salvador Dali had owned a computer, would it have been equipped
with surreal ports?"
N
Norman D. Crow
"the other guy" had opened the breaker) I was rather surprised to be alive
and unhurt afterwards. I did some research and found out it is almost
IT ISN'T THE VOLTAGE! When I was in USN, they had studies showing deaths
from relatively low voltages. It's the amps, or more precisely the
milliamps, and where they travel. A certain milliamp current can be lethal
if it passes through the heart/chest area because it will cause the heart to
go into fibrillation, while a relatively high current may just cause the
heart to stop, but once it is removed the heart will restart on it's own. I
don't remember the exact numbers, but seems like it was around the 90-100
milliamp range that was lethal due to causing fibrillation.
George
Your heart operates on considerably less potential. You're betting that the
jolt won't find the proper pathway to interfere or stop it? Foolish wager.
Two in my experience on 120 Volts, but that's 50% of electrocution
fatalities I've had.
toller
old).
able to handle it.
I certainly agree that the cord should be replaced; but it is not
particularly dangerous. To get any shock, you would have to both short the
hot to the frame and break the neutral. While certainly not impossible, it
isn't likely. (Though I just threw out a 60 year old waffle iron with
exactly this problem; well actually it was shorted before the switch, so it
was like a broken neutral.)
Even then, the bigger danger is dropping a saw with a spinning blade than
electrocution.
My oven, like millions out there, has the neutral attached to the frame;
which is essentially a deliberate short. Unless the neutral is broken, it
is harmless. It is a foolish setup, and is now contrary to code, but you
would be hard pressed to find anyone hurt by it.
Doug Miller
Once again demonstrating that you have _no_business_ giving electrical advice
to anyone. _Of_course_ it's almost impossible to get a lethal shock under
"normal circumstances" because "normal circumstances" don't include doing
stupid stuff like putting your hands across a live circuit. It's _abnormal_
circumstances that are dangerous, and it is indeed quite possible to receive a
fatal shock from 120V when something has gone wrong - like installing a stove
with its equipment ground connected to the circuit neutral conductor, as you
recently told someone to do.
And only an idiot would assume that "the other guy" had opened the breaker,
and not check first. Hell, I check before touching even when *I* am the guy
that opened the breaker - just to make sure I opened the right one.
If you work on your own wiring, I hope you live alone. I'd hate to see anyone
else's life jeopardized by your ignorance.
Regards,
Doug Miller (alphageek at milmac dot com)
Nobody ever left footprints in the sands of time by sitting on his butt.
And who wants to leave buttprints in the sands of time?
Guess who
Either this is a troll or you are a moron. Take your pick.
toller
You are correct; 100ma is about the lethal threashold. But it is difficult
to get 100ma off 120v unless you are in saltwater.
Naturally adverse medical conditions, or just plain bad luck, will change
everything!
Leon
After a delivery truck hit a power pole and knocked down some power lines I
questioned the gentleman managing and keeping an eye on the crew repairing
the power lines. He indicated that 220 is more likely to get you as it
tends to hold on to you. The much higher voltage lines will more likely
throw you away.
LRod
Glad I'm not the only one that does that.
Neither of you are (the only one). I do, too. It's too easy to check,
and the potential consequences of not checking are too high.
LRod
Master Woodbutcher and seasoned termite
Shamelessly whoring my website since 1999
http://www.woodbutcher.net
Proud participant of rec.woodworking since February, 1997
Robatoy
If a PaceMaker can keep your heart going with fractions of milliwatts
and low voltage, WTF makes you think that ANY electrical current is safe
or safer?
A ground is there to conduct possible power away from where it can cause
damage. To knowingly operate a metal tool without a proper ground is
just plain fucking stupid. Nothing else sums it up better. You are a
fucking moron.
Or a troll.
I'm going with both.
Robatoy
I think the OP was trolling, judging by his lack of response. It looks
like he hauled in a whole netfull.
At the risk he was just an ignorant fool, I decided to respond anyway.
But I think you're probably right.
