Paul E. Schoen
- Jan 1, 1970
- 0
Monday night, while working at my computer, a strong thunderstorm moved
through this area, which is a very damp valley leading to the Loch Raven
Watershed area in MD. Hearing several thunderclaps seconds after flashes, I
considered shutting down my computer and disconnecting the power cord and
phone line. A few seconds later, I saw a bright flash and an immediate loud
"boom", and all power went out. I smelled something that could have been
ozone or burnt phenolic. I set up emergency lighting, looked for any signs
of fire, and took a brief look outside. Electrical power along the road up
to the junction with a main three phase feeder was out, and both my phone
lines were dead. Luckily my pets and I were not.
BGE arrived about 5 AM the next morning, determined that a fuse had blown,
and power was soon restored. When it was light enough to see, I looked for
other signs of damage outside. I have two houses separated by about 80
feet, and at the corner of the second house (used for storage) stands a
huge Sycamore tree, probably 150 feet high. I found some wet, broken
branches, and some pieces of bark, but no signs of major damage. However, I
noticed that several panes of glass in a window just about two feet from
the tree were broken, and two of them appeared to have blown outward. It
looked like a raccoon may have jumped through the glass (which is possible,
as I have found them in that house). Also near the tree is a 240 VAC
twisted utility line, actually touching the tree at one point, and a drop
cable to a meter box which is disconnected. I do have power to the house
through a UF cable for convenience, fed from my residence on two 20 amp
breakers. Also just below the power line is my active phone line, which
connects to an interface box and then through a four wire line to my
residence.
I discovered that one of the breakers had tripped, and I reset it with no
problem. There was a second storm in the afternoon that caused loss of
power again, but it was soon restored. The telephone technician found 48
VDC and a dial tone on one of the pairs, but not the other, and replaced a
blown protector device which restored one line, but the other seemed to be
an open circuit to the pole. An access box on the pole was open, possibly
from the lightning strike or perhaps it was being repaired by another
technician.
The damage to my equipment included a blown modem in my computer, damage to
my computer speaker internal amplifier, and a damaged phone answering
machine. I feel lucky.
I don't know the exact path of the lightning, but I think it may have hit
the 15 kV (probably) main line and arced over to the transformer secondary
and over to the tree, where it traveled down the ground paths. I think a
direct hit to the tree would have caused more damage. I am curious about
the pattern of the broken glass in the window, however. At first thought, I
would expect lightning to ionize the air and create steam pressure from
rain, so it would be an explosion with outward force. I think this caused
some of the initial damage to the window, as evidenced by glass shards
inside the house. But I think this may have been followed by a partial
vaccuum that caused the sudden expulsion of higher pressure air in the
house through the cracked glass. I will take pictures of it before I repair
it.
It was almost prophetic that I was just reading some posts in SED
referencing high voltage arcs and lightning, and also now reading the other
post about conductivity of trees.
Now it's raining again, and I think I hear thunder.. AIEEE!
Paul
residence.
technician.
it.
Paul
