Closed caption text turn off WITHOUT the remote
  • Thread starter Jacques Carrier
  • Start date
Jacques Carrier
Hi fellow techs,
Is it possible to turn off the closed caption (text mode) from a JVC color TV
model C-13WL5 made in 1994.The remote control has been lost and I am tired of
borrowing my friend's remote.The original remote costs $70.
The IC that seems to control the closed caption display is the following:
MN1873237JKH6 (64 pins).Can I turn ON/OFF the closed caption at the IC level ??
I contacted JVC three times ....but no reply.
Many thanks to all and best wishes for 2004.
Jacques
Tim Marcus
I do not recommend this, but I got rid of the on screen display on an
older emerson tv by shorting one of the pins of the IC to ground.
However, there was no longer any display ever, even when changing
channels. when you can't find the remote, extreme measures must be
taken. good luck- Tim
Jerry Greenberg
You need the origional remote. The function you want, along with many
others is controled internaly by software. The remote is sending a
data stream via the remote IR receiver in the set to the uPC. The uPC
issues a software to do the action. I don't know the particulars of
your set's design, but the function may be external to the uPC in
another chip, or it may be all internal. The commands are all
software, and in most models are not externaly addressable.
You should invest in the origional remote if you are using the set.
Or, borrow a remote to turn it off, and then leave it off.
Jerry G.
Deke
Jacques Carrier said:
Hi fellow techs,
Jacques
Buy a learning remote, borrow the friends remote one last time, program the
learning remote.
Be sure and write down what key does what, dont trust your memory. Done.
Deke
David
Or get the software for your Palm Pilot to learn the remote control for you
JVC after borrowing the remote one last time.
David
