maxfoo
- Jan 1, 1970
- 0
maxfoo said:
The 'fun' bit comes, when you have multiple coils, and capacitors, and addAnthony Fremont said:Seems an odd way to have the coil for an electromagnet, I used the
innards of a Ford starter solenoid. I used an 400V 820uF cap charged to
about 300V. I used a PIC (of course ;-) to generate the PWM signal and
measure the cap charge thru a resistive divider. For the switching
transistor, I used an IGBT. An SCR dumped the charge into the solenoid.
On a good launch, it would throw a computer case screw across the room.
Seems an odd way to have the coil for an electromagnet, I used the innards
of a Ford starter solenoid. I used an 400V 820uF cap charged to about 300V.
I used a PIC (of course ;-) to generate the PWM signal and measure the cap
charge thru a resistive divider. For the switching transistor, I used an
IGBT. An SCR dumped the charge into the solenoid. On a good launch, it
Sven said:The reason I can see for using ferrite cores this way would be to
protect the mosfet, as they moderate the current a bit. Apart from the
fact that a simple solenoid wouldn't look that impressive!
I'm referring to direction of the wrapping with the core being parallel to
the windings instead of perpendicular. AFAIR, I have never seen an
electromagnet constructed this way.
opto-detection of the projectile, to fire the next coil. Once the speed
gets up to a few hundred m/sec, the timings begin to get quite critical.
Large flash-gun capacitors work quite well.
Best Wishes
