Combined Wind and Solar Power System
Ian Christie
Feb 19, 2010
I'm not sure that this is strictly an electronics project but let's see how I get on.
I have a 2 kilowatt solar cell installation on my roof. It is connected via an inverter/regulator to my mains supply (not a battery system) and either reduces the amount of power we draw from the grid or else it pumps power back into the grid. (I get paid paid at a premium rate for power sold back!) I am considering adding a wind generator of about 600 -1000 watts and would like to use the same inverter etc for the turbine.
Everything I have read about wind generators assumes they are connected to a 24V battery bank. Has anyone done anything like what I want to do? I've tried a couple of sustainable energy web fora and everyone there is using either solar or wind but not both unless they are completely off the grid and running off a battery bank. I'm in the middle of Melbourne and have no desire to become totally independent of the grid but reducing my carbon footprint seems like a good idea. (We are into the 12th year of continuous drought here.) I've got a solar water heat already, the water tanks go in in about two months, the house is insulated, my wife and I ride bikes to work. The only thing we don't have is wind generation.
So what I really want to know is:-
How do I connect a wind generator to a photovoltaic cell system which is connected to the grid?
Resqueline
Jul 31, 2009
2,848
I don't have first-hand information about this but I'll say what I think anyway.
The PV system has quite a high voltage I presume. That means you have to get a generator of around the same voltage. If ever there's sun & wind at the same time then the inverter has to be rated for the sum of the powers. The generator will have to be of the self-limiting type. Just hook the generator in parallell with the panels. Unless the panels have built-in isolation diodes you will have to connect them via a diode.
If you point me to a spec. sheet on the inverter I might be able to say something more certain.
