Compact fluorescent - voltage
K
Ken
On 30 Sep 2006 08:29:07 GMT,
What voltage do all these compact fluorescent "lamps" use ..?
And what waveform/frequency is required (used) ..?
They are current dependent.
Eeyore
They run off standard 50/60Hz A.C. line voltage/current e.g. 120V or
220-2440V. The internal electronics sorts out what's required.
What did you *really* want to know ?
Graham
Aly
You can run them off a small 220v/12v mains transformer in reverse, wired in
a flyback configuration. That means, a transistor, and letting the thing
self oscillate through one of the windings. The frequency all depends on
how the transformer is built and will vary from manufacturer to
manufacturer. But you can run a small tube off of a 9v radio battery.
The terminology is roughly right there and someone will offer a better
explanation. All I know is that from tinkering that it works. These
handheld flashlights will have a small specially built transfromer meeting
the specifications of the the tube the manufacturer chose.
There's a bit on this on the DIY hobby sites somewhere. Google it.
I want to know what is applied to the *tube*, because I want to possible use
the ballast for other purposes. Like 48V dc -> 12V dc, after all they seem to
have all the stuff for a dc/dc converter.
Eeyore
An LCD backlight is essentially the same thing AIUI. You'll find plenty of info
on drivers for them. IR have some dedicated CFL drivers too.
Graham
PeteS
Graham
CCFL backlights typically run at 400 - 700Vac (depends on the
backlight) and the start voltage is usually about twice the run voltage
give or take a handful.
Normal run currents vary - a very common run current is 5mA.
I have one I am using (although I won't be soon - going to white LED)
that has a nominal run spec of 680Vac with a start voltage guaranteed
at 1500Vac (typical 1250 Vac)
Cheers
PeteS
Jonathan Kirwan
Have you tried googling about it or using Wiki? My recollection is
that the compact fluorescents operate in the 20kHz area and operate at
a low power factor, but I did what you should have done, I think. I
went to wiki and google and quickly identified this page:
http://www.irf.com/technical-info/designtp/irplcfl1.pdf
That probably provides as much detail as you may need.
But please try spending a little of _your_ time searching _and_
informing us first about the scope and limitations of what you found,
next time. You may have done some searches already, but you said
nothing about that.
Jon
JeffM
_and_ informing us first about the scope and limitations
of what you found, next time.
but you said nothing about that.
His ridiculously long username, his sloth, and posting to s.e.d
all may make him look like a n00b--but he ain't.
http://www.google.com/search?q=Peter-Brevik+ludd.luth
http://groups.google.com/group/misc..._frm/thread/a745803e07dec834/72e90baaa56a607f
....and you're right: He should know better.
default
On 30 Sep 2006 11:04:28 GMT,
I ain't no ex spurt but I took one of them suckers apart.
The one I played with. Had no isolation! first off - you'd need a lot
of experimenting to make a DC converter out of it. What they did was
rectify the line in and then chop it (on and off real quick with
discrete semiconductors) then routed the chopped DC through a
capacitor to the tube. and had another circuit to work the heaters
from the line (yes, it wasn't cold cathode)..
That was my first (or second) thought when I had one burn out. How do
I make a 12 PS out of this? Conclusion: ain't too likely.
Now those little 5.7 volt isolated 800 madc converters they make for
Nokia phones? The local store sells them for $5 and when I get the
time . . . .
nothing about that.
I have been searching on google/wiki a lot but I didn't find anything
useful. I figured if I know the voltage on the tube I can approximate
the transformer ratio in the ballast.
I need the transformer for an PoE project. But I also figured CFL ballasts can
be used for cheap dc/dc (48->12V) converters. Another source for cheap dc/dc
can be those mobile phone chargers. But I suspect they have too high ratio on
input/output (230->4V) voltage. And they are harder to get by in large amounts.
LCD drivers have some nice big transformers on their pcb. However they are
harder than CFL ballasts to come by, and are more cumbersome to handle. As
there usually is a whole laptop included ;)
Jonathan Kirwan
nothing about that.
useful.[/QUOTE]
Well, I had no way of knowing any of that. It would help a lot to
know what you didn't find useful and where you had looked, already.
It's better to write more, than less -- up to a point. You respect
the time of others, that way.
I figured if I know the voltage on the tube I can approximate the
You haven't mentioned whether or not the article I pointed out was any
use. It's quite possible it isn't.
I don't imagine a "voltage," here. There is a necessary cold starting
voltage and perhaps some other steps early on, but once ionized, isn't
it the case that current control is the important issue?
I remember from doing a flash lamp many years ago (30) that the
voltage supply is something like 300V or thereabouts. My guess is
that compact fluorescents with tube lengths somewhere in the
neighborhood of a similar length will need roughly similar voltages,
with starting voltages much higher (I had to use about 4kV to trigger
the lamp, memory serving, supplied by a trigger transformer driven off
of the 300V on its primary winding.) What's actually required to
start these lamps, I don't know.
If my memory serves on another score, to avoid depositing needed gas
atoms on the tube surfaces, it's important to use AC and, if possible,
fairly high frequency AC is better than low frequency (up to a point,
which seems to be about in the area of the 10-30kHz.) The better
frequency to keep the atoms from depositing is a matter for physicists
to discuss, but I think that frequency is a typical area.
So these do NOT seem appropriate for dc to dc converters. The parts
may be useful, such as the current limiting inductor, for example. But
the design topology seems all wrong to use in its entirety.
I don't know what a "PoE project" is, but I do know what a 48V to 12V
dc/dc converter is, generally anyway. Since you are into adaptations
of one kind or another, why not just design and build one and scavage
parts from where you can?
Jon
I tried for some time to find the answer so to say. But I figured I had
reached something not well documented. And it was proberlbly a better idea to
just ask then to search in absurdum.
I tried to limit the requested data instead. A quick way to find out is with
a scope across the cfl tube. But high voltages >1kV makes it risky.
It's proberbly useful. I haven't yet read it in depth yet thoe.
Yep, in many places it says have current limiting or else *P0FF*
So far my guess is fire voltage ~800-1500V, and run voltage ~300-600V.
The useful threshold seems to be 20kHz. But due audioable noise higher
frequency is proberbly prefered.
My thought was to reverse the transformer and put the rectifier + capacitor on
the output. Guess that idea is toast thoe ;)
There are designs for dc/dc but they still require an inductor.. thus looking
into cfl ballasts.
The PoE project is about power over ethernet. You send some sense signals and
then apply 25-60V dc max 400mA over cat.5. But one need a 3:1 isolated
transformer. I just want to make a quick bench test of the schematic before
ordering the real stuff.
While looking into this I figured a 48V dc distribution network would be useful
for power distribution to computer equipment in the building useing thicker
cables than cat.5. And cheap sources for 48V -> 12 or 5V dc conversion would
be nice. So I thought maybe the cfl ballast could be modded into this.
However it seems this was not the case ;)
H
Homer J Simpson
Nope. There was a model that used an incadescent lamp as a ballast for a 4
foor fluorecent lamp. Ran off 230 VAC - no igniter IIRC.
If they ran off about 50 or 60 VAC I wouldn't be surprised.
Jonathan Kirwan
Hmm. I just went over to that PDF file I'd mentioned and they seem to
talk about 300V there. So perhaps I'm not far off base.
Well, I'm almost dead certain that compact fluorescent (at least,
those in the US) run at high frequency. The long ceiling tubes _do_
run off of 50-60Hz, as you say. But not the compacts, as I understand
it.
Jon
H
Homer J Simpson
it.
Sure. Even the 4 footers can come with electronic ballasts now - less
flicker and buzz. But there's no sign of an igniter system so they strike
off 110 VAC.
H
Homer J Simpson
your sure about that ?
Wouldn't bet my life on it but it seems so. Still, it's hard to figure what
is happening at that frequency.
