MRW
- Jan 1, 1970
- 0
Hello!
I am reading about comparators. I happened to be using this one:
http://www.national.com/pf/LM/LMC6762.html
According to the application hints in the datasheet, "generally, it is
a good goal to reduce the delta voltage on the power supply to a value
equal to or less than the hysteresis of the comparator. For example,
if the comparator has 50 mV of hysteresis, it would be reasonable to
increase the value of
the local bypass capacitor to 0.01 μF to reduce the voltage delta to
10 mV."
I understand this portion clearly. But what I don't understand is: how
do you determine the comparator hysteresis? Does this refer to the
built-in hysteresis in the comparator? Or is this related to any
hysteresis due to external networks?
By the way, I could not find any values associated with the comparator
in the operating tables.
The application hints also has a section on hysteresis, and they show
an example by putting a resistor and capacitor in the feedback network
of the non-inverting input. However, they do not indicate what kind of
hysteresis value you can get with this setup.
Thanks!
10 mV."
Thanks!
