Hello everyone,
There is a block diagram as attached. and I should decide if an alternative pin to pin compatible OP (as impedance converter in the circuit )with this part number TLV342AIDR can be replaced instead of this OP with part number AD8692ARZ on a big board,
that is, I must not replace the whole board if possible.
Now, my question is how could I compare these two opamp to understand that if the alternative one could do the same job with 100nF load? Because the old board has the ability to tolerate 100nF without additional way.
P.S: On the data sheet I could not find a proper comparison
best regards,
Somayeh
