RKovach
- Jan 1, 1970
- 0
I have read that you can use a lab scope to check the secondary firing
patterns by connecting an inductive lead to the coil wire on #2 channel, and
connecting another lead to the #1 spark plug wire on #1 channel, and use it
to trigger the signal. This will show all the plugs, in the firing order, in
1 trace.
Can this somehow be used on a distributorless ignition system that does not
use 1 coil for all the plugs? Is it possible to use 5 pickups, for a 6 cyl.
engine, all wired together, and connect this to the #2 channel and connect
the #1 as above to get the same results?
1 trace.
