Controlling a relay via cellular phone.....
EsDee
Since a few weeks I am running a webcamserver . It is stationed 40
Kilometers away. I control it via an UltraVNC connection. However, about 2
times a week I need to hard-reset the computer manually.
I am looking for some kind of construction to reset the computer via a GSM
cellular phone.
The only thing I need is a relay that I can switch by making a call to the
GSM phone. So, I need only 1 channel.
This relay could switch the reset-button.
Can anyone help me out?
Thanks in advance.
Marcel
Michael A. Terrell
EsDee said:
cellular phone.
Thanks in advance.
Marcel
Why not use the printer port and just issue the right command to pull
the reset line low with a DIP or reed relay?
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Guest
Maybe he needs to reboot because the computer gets locked up, in which case
he would need an "outside line".
martin griffith
cellular phone.
Thanks in advance.
Marcel
Think you may have missed a few groups!
<paranoia>
****BANG****
FBI/CIA... what account was this?
Geneva,
OK no probs
</paranoia>
or just do a nice stir fry, lots of veg, hot oil and Wok. Beats
McDonalds anyday. And you dont fart as much
martin
John Larkin
cellular phone.
Thanks in advance.
Marcel
Vibrator motor drive?
John
Guest
I wouldn't want a computer that rebooted every time it's telephone number
rang, so I would plan on sending a coded tone signal. The buzzer signal
could be routed to the push to talk (answer) button so it would
automatically answer every call, but off-hand I don't know how to hang up,
if you are planning to remote detonate a bomb then you won't need to hang
up.
Paranoid? I AM THE KING OF PARANOIA!!
Eeyore
EsDee said:
For a second I thought you were a terrorist bomber !
Graham
Si Ballenger
cellular phone.
System admins use the below x10 telephone gizmo to remotely cycle
the power to hung servers to reboot them.
http://www.x10.com/products/x10_tr16a.htm
John Fields
up.
Paul Hovnanian P.E.
I think al Qaida has details on how to do this posted on their website.
EsDee said:
cellular phone.
Ask yourself how many wrong numbers you get per week. Ask yourself
whether you really want your computer reset everytime someone misdials
the number of the pizza-parlor. Ask yourself whether you really want
everybody on the planet to be able to reset your computer at will.
Including everybody on usenet, once someone finds out the number you
assigned to this and posts it here.
I'm sorry, but no functional computer needs to be reset twice a week.
Hitting reset everytime your computer hangs is like buying a new car
everytime the old one runs out of gas. It is the desperate attempt to
avoid solving a problem.
If your computer hangs that often, then your setup is broken -- either
in hardware or in software. Fixing it will not only save you money in
the long run (no need to keep a GSM) but will probably teach you a
bunch of things. Some of which might even come in handy in the future.
cordially
Y.T.
Michael A. Terrell
If it's locking up, the printer port makes even more sense. Output a
pulse at a regular interval. If it stops, your controller resets the
computer. A simple missing pulse detector and a little thought will
show you how it works. Think of it as an external watchdog timer.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Guest
Thank you. You are correct, I think. I didn't catch on to the use you had in
mind.
Guest
Did anyone ever tell you about the huge voltage potential between the
electron gun at the back of your monitor, and the screen you have a few
inches from your nose.
RUN, RUN
tapwater
Professional Chicken Plucker
Jim Thompson
RUN, RUN
tapwater
[snip]
Isn't the correct spelling "PHUCKER" ?:)
...Jim Thompson
Spehro Pefhany
You can buy cards that implement the WDT function for PCs.
Best regards,
Spehro Pefhany
Guest
Buy? Wait, I have to turn the crank on my home-made electrical generator.
There, that will hold it for a few minutes. What means this word "buy"?
Thank you for the information, and if I ever get some money I will learn to
buy stuff.
Best regards,
Spehro Pefhany
http://www.speff.com
Guest
You can spell what YOU do any way that you want to.
RUN, RUN
tapwater
[snip]
...Jim Thompson
