K
Ken Moiarty
- Jan 1, 1970
- 0
Hi, I'm trying to search the web for 19" to 22" CRT monitors on the market
which provide the *highest refresh rates per a certain range of resolutions
(e.g. starting at 1024 x 768 thru to 1600 x 1200). In other words, I'm
looking for monitor product specs that show a list of resolutions and their
corresponding maximum refresh rates as would be presented in a table. This
is hard to tailor a Google search for.
Therefore for keyword terms, I'm turning my attention to "video input
bandwidth" (rated on the order of hundreds of mHz, rather than the mere tens
of Hz that apply to vertical refresh rates) as a search term/variable to use
in my searching. In my browsing I get the impression that the higher the
value of this "video input bandwidth" parameter, the higher the refresh rate
possible for a given resolution (when all other things being equal, of
course). But I seem unable to find anything to confirm this hunch.
If someone here, who is more knowledgeable than I on this subject, could
please enlighten (and/or correct) me here, or just point me towards a good
faq site on this topic, I'd appreciate it very much. For example, is there
any kind of linear mathematical relationship between a monitor's video input
bandwidth value, and it's refresh rate values relative to various possible
resolutions? Or perhaps you might just tell me what might be the upper
limit or ceiling in terms of the maximum "video input bandwidth" values
realistically obtainable (e.g. 300mHz?, 350mHz?, 900mHz?, what?). Then I
could have some idea of what range of values I might begin punching into my
Google search attempts (as in, 'try this and see what me comes up with',
etc...etc...) .
TIA,
Ken
* FYI, for those who just may be curious: Because of local problem of 60 Hz
alternating magnetic-field interference emanating from a major high voltage
powerline corridor running right through part of my back yard, in order to
make good use of a CRT monitor I have to run it at refresh rates that are
multiples of 60 Hz (e.g. 60 Hz, 120 Hz, 180 Hz, etc.).
One might think the preferred alternative might be to just get an LCD
monitor (or if spending gobs of money for ugly aesthetics were somehow not
objectionable, have a custom made mu-metal monitor-enclosure made). The
complicating factor here is however is for my purposes here an LCD monitor
won't do. (I have already invested in an LCD monitor for regular computer
use.) Here I'm looking for a monitor which I can use for viewing very
high-quality high-resolution Stereo 3-D video, and this can only be done
using a large CRT monitor.
Further necessitating the desire to search for a CRT monitor based on the
highest refresh rates available, not only must this monitor refresh at some
multiple of 60 Hz to avoid local electromagnetic interference as I just
mentioned, but because of the demands of high quality stereo 3-D viewing the
vertical refresh rate absolutely cannot be anything less than 120 Hz;
although in fact a somewhat higher refresh rate than 120 Hz (e.g. 135 Hz) is
preferable in order to avoid noticeable flicker during 3-D viewing. (This is
only because, although the monitor is refreshing at 120 Hz, stereo 3-D video
is using two vertical scans to produce one interlaced stereo 3-D frame,
meaning the actual stereo 3-D refresh rate rate is still a mere 60 Hz as far
as each eye is permitted to see (due to the stereo 3D shutter glasses).
This results in flicker just like that experienced with a monitor set to 60
Hz refresh rate for general use.) Therefore given the constraints imposed
by my powerline interference problem, to achieve a monitor refresh rate
above 120 Hz, I would have to leap to the next multiple of 60 Hz, which
would of course be 180 Hz refresh rate. And to achieve this refresh rate in
and of itself, it is not difficult to find a monitor capable of 180 Hz.
What is proving difficult however (for me at least) is finding a monitor
that can refresh at 180 Hz whilst display at 1024 x768 or higher resolution!
And btw, not even this is the end of the story: In addition to the above
requirement, the monitor's horizontal sync frequency must be no less than
126 kHz --ideally 130-140 kHz. Thus I must be sure to avoid any monitor in
which this parameter has been compromised by the manufacturer the interest
of competitive pricing, knowing that many monitor buyers will simply not be
aware in this regard. But this parameter simply is not mentioned or even
referred to in the specs provided for any of the CRT monitor models I've so
far been able read about on the web. (See
http://pymol.sourceforge.net/stereo3d.html , if anyone wants to see the
source of my info pertaining stereo 3-D video.)
etc...etc...) .
TIA,
Ken
