CTC 203 blows the output.
Dani
Model # F32649 Chassis # CTC 203 CA9 @ turn on relay clicks a couple
of time...horizontal output shorted 2SC5148, caused by a bad connection
@ C14402 .0168 1600 volts, & the capacitor measures ok. All else
checks
ok, & the T.V. runs fine, voltages ok, & pix fine...couple of minutes
later
power supply squealing, output shorted again. Connections, & horizontal
drive has been soldered. I don't have a flyback ringer. Ideas? Dani.
I
ian field
checks
later
What does that cap you checked OK do? Running for a few minits and then
blowing the H-transistor is typical of flyback tuning cap gone low in value.
If it runs for a few minutes, shorted turns in the HOT would have time to
get pretty hot!
Bill S.
checks
later
Check the little choke in series with the HOT base drive. Common
problem was contaminated solder joints. Some folks said it was
from glue used, or maybe the wire wasn't clean enough. Resistive
connection can cause insufficient drive current which makes HOT
spend too much time in linear conduction and burn up.
I
ian field
Some monitors (and probably some TVs) have an electrolytic in series with
the base drive, it can dry up with similar results!
Similar threads
