Cuisinart Grind and Brew parts?
H
Holly
I have a Cuisinart Grind and Brew coffee maker that needs a new board
(where the off/on and other buttons are located). I can see that it
easily can be replaced but cannot locate a new one. Does anyone know
of a source for this.
Any help very much apprecited,
Holly
James Sweet
Holly
What's wrong with it?
H
Holly
Only some of the buttons respond when you press them. If you press
"grind off" the button lights but if you press "on" nothing happens. I
got over aggressive with washing it and I think I got water in it. I
have opened it up and tried placing it in front of a fan for quite a
bit of time and it hasn't helped.
James Sweet
It could also be water on the main control board, it can hide under
chips for a while causing odd problems. My first suspect would be the
control panel though, if you can remove the board, wash it off real well
with isopropyl alcohol and then dry it out with a hair dryer and try
that. If it really does need to be replaced, you could contact Cuisinart
but it's likely the board will cost nearly as much as a whole new unit
if it's even available separately.
