Curious buzzing sound on AM car radio
Spooky
Hi All,
I have a Motorola push-button AM car radio which is plagued with a
buzzing sound on its audio. It is present at the low end of the medium
wave band and it is right across the long wave band too. At first, I
thought it was noise coming through the DC power adaptor I was using,
but it was still there when I ran it in my car from a DC outlet. The
buzz is only present with an antenna is connected and it almost
disappears when you place a hand on the top of the radio chassis. I
can't pick up this interference on any other radio and my ground
connections to the chassis seem fine. I'm at a loss as to where to
start fixing this! Any suggestions will be gratefully received.
Regards,
Gary
Porky
Your antenna lead may have a break in it or something loose at the
antenna end. Check the routing of the cable under the dash.
Dave Plowman (News)
In the AM only days, it used to be the practice to use a thick braided
earth strap from the radio chassis to a nearby body ground, even if it had
a ground power wire. There was usually a captive 1/4" bolt on the back for
this purpose. Think the theory was that RF needs a lower impedance ground
than the power lead which may well be grounded someway off at a central
point, and pick up interference.
Mark
is it really old i.e. does it have a vibrator type power supply? does
it have tubes? or is it all solid state? how about if you drive your
car to a field away from power lines and houses?
Mark
