What I'm wanting to do is probably fairly simple but my background is not in the electrical/electronics field.
I want be able to detect current flow through a 16ga wire and turn on a LED when current is flowing.
As a mentioned I'm working with 16ga wire and will be connected to 110 volts running about 6 amps but would need to be safe up to 15 amps. The whole set up needs to be as small as possible! I know how I could make it work with a current donut but they are to big for this application, what else could I use to pull this off?
Thanks for the help
Thanks for the help
