current transformers
Craig
Hi everyone.
COuld anyone help me with a problem I am having interfacing a current
transformer to a PC. I have a 50/5A curent transformer which, via a
ballast resistor produces the usuual variable AC Voltage on the
secondary. My problem is I need this AC converting to 0 to 2.5V DC to
power the PC interface and I am having great trouble coverting it. The
normal diodes/bridge rectifier don't seem to work. I suspect this could
be to do with losses in the diodes but my electronic know-how doesn't
streatch this far. Any help would be greatly appreciated.
martin griffith
Hi everyone.
try this
http://sound.westhost.com/appnotes/an001.htm
you will need a negative supply for the opamps, despite the output
only going positive.
You may need a reverse biased diode across the input of the ADC, 1n914
etc, to stop any -ve volts on powerup
martin
Baron
Craig said:
Hi everyone.
could be to do with losses in the diodes but my electronic know-how
doesn't
What frequency range are we talking about ?
What are you doing to convert the output ?
What is the input impedance of the PC interface ?
A schematic would help ! Post it to
"alt.binaries.schematics.electronics"
neon
Oct 21, 2006
1,325
you need to amplify the signal diodes drops will elininate your signal at low current it disconnect. not to mention linearity.
Jamie
Craig said:
Hi everyone.
you need a precision rectifier and op-amp etc..
didn't you ask for this before?
use a dual op-amp to for a full wave precision
rectifier. in order to get a nice 0 to 2.5 v how ever.,
you should employ a negative rail supply.
DC-DC converter is great for this from a single power
source.. or i suppose you could whip up a DC to DC from a
a 555 timer to get a - voltage regulated , i've done that
before how ever, you will find that a simple single chip
charge pump DC-DC dual rail us most likely less parts count.
unless you pull the trick i've seen before, use an RS-232
port and have output leg off for - voltage, and one on for
+ voltage. and use a min pic to convey the info via rs-232
serial.
just simply use a USB to rs-232 converter ... etc..
John Popelish
Craig said:
Hi everyone.
This topic was discussed in considerable detail last
September in a thread titled "Help interfacing Current
Transformers to ADC" A Google groups search should give you
a fair head start.
F
Fred Bartoli
martin griffith a écrit :
You're hexasperating...
And to do so he has to turn his par(i)ty bits to one more digit.
