Custom USB Cable
N
natcire
Am looking to build a mini-USB cable with an RJ-11 plug on the other
end.
Do/can anyone share with me their knowledge on building such a cable? I
need to be able to transfer/receive data through a USB device to an
analog phone device (RJ-11).
Will greatly appreciate any assistance.
natcire
Paul Hovnanian P.E.
end.
I don't think there is any standard for using USB with such a connector
so you are on your own.
The device into which you plug this custom cable will still have to
support the USB protocol as either a USB device. Simply plugging it into
an analog device with an RJ-11 jack won't work.
There are some USB modems and serial to USB converters that you could
use to get from an RJ-11 telephone type interface to a host through a
USB interface. This is what it sounds like you are going to need. If so,
stick with whatever USB connectors it comes with.
Joel Kolstad
end.
You're going to need alot more than a cable to make this happen. Can you
just use a USB modem? It already has a (regular sized) USB connector on one
end and an RJ-11 connector on the other...
What are you trying to do?
Richard Crowley
end.
If we read between your lines, it sounds like you are looking
for a traditional analog telephone modem. There should be
many of them available with USB interface. Just buy a USB
cable with the appropriate connector on each end.
If that is NOT what you are asking for, you will need to fully
describe what is at the RJ-11 end of your cable? And telling
us what you are trying to do would be extraordinarily helpful.
