cutting pcb
Patt
What do you use to cut a perforated circuit board? I need to cut a roundish
piece from a bigger piece.
Patt
Nibble cutters work pretty well, or abrasive or carbide rotary bits.
The latter make a nasty mess tho. I've used a bandsaw, but if the blade
is dull it takes forever to cut through FR4, and it makes the edges all
feathery.
Y
Yukio YANO
Patt
I've always used a Jeweller's Saw. It looks like a small Copping saw.
Look in a Hobby store under Lapidary Supplies and Jewellery making. Buy
a Dozen blades of a couple of pitches at a time. Remember to mount the
blade to cut on the PULL not on Push as a western Carpenter Saw.
Yukio YANO
Howdy Patt......I usually use a powered scroll saw (a hand coping saw
does the same job) and finish up lightly sanding the edges (400 grit) if
required. Making a cut-out of a pcb can be done the same way.
Gord
andro000
Patt
I use an xacto laser saw for the bulk of the cutting. Finishing inside
corners with a jewlers saw like the one mentioned above. I coat the
jewlers blade with bees wax to avoid binding. I then finish the edges
with 320 sand paper.
andro000
Patt
default
Patt
Hole saws for round pieces. Tin snips work well for straight cuts, or
nearly straight. Saber saw with a narrow blade and large offset to
the teeth. It's a little hard on the blade if you do fiberglass - but
a paper cutter will make straight cuts.
