Cypress HOTLink communication monitor.
Cristian210273
Hi design gurus!
Sorry if the question sounds silly, but I'm a newbie in the field.....
I need to monitor the HOTLink communication between two devices.
Following some questions:
1) Can this communication be monitored without acquiring the signal in
input and put immediately in output (i.e. without filtering it with
dedicated
HW)?
2) Is there any commercial product having LINUX drivers?
Any help would be appreciated.
THANKS!
Hi design gurus!
dedicated
HW)?
THANKS!
IIRC, this is a fairly old chipset (10 yrs +) that enabled some sort
of high speed link. It used 10b/8b encoding.
250MBps I think.
Just for fun I'd use an active FET probe with 2-3GHz bandwidth and a
50 ohm out.
Probe the hotlink channel with the FET and feed a hotlink chip
directly with the probe output, assuming there's no nasty DC on there.
Have the hotlink chip barf its bytes into a big SRAM and read them out
later.
It's a PHY layer only, so you would have to know what you're looking
at and interpret the data yourself.
