Daewoo 27 in T.V. sound garbled than fades away 1 to 2 hrs
sound is good for about 1 to 1.5 hrs than it starts to garble than
fades away.
if you turn it off for 5 or 10 min the sound is back than starts cycle
over again.can anyone help Thanks
Jerry G.
Check for components that have become thermo sensitive. You will need some
liquid air ( a product called Freeze Mist ), and a heat gun to troubleshoot.
Carefully heat and cool the suspect components. Start in the audio sections
of the set.
I would strongly suggest that if you are not trained and equipped to do TV
service, you should give the set out for this type of service.
Greetings,
Jerry Greenberg GLG Technologies GLG
WebPage http://www.zoom-one.com
Electronics http://www.zoom-one.com/electron.htm
fades away.
Shoreline Electronics
What's the model #?
Jeff Stielau
Shoreline Electronics Repair
344 East Main Street
Clinton,CT 06413
860-399-1861
860-664-3535 (fax)
[email protected]
"If you push something hard enough it will fall over."
Fudd's First Law of Opposition - Sir Sidney Fudd
