DDR SDRAM static timing analysis
I need a help in static timing analysis for DDR interface to network
processor . Processor say that its timing is as per JEDEC standard.
For Read i will be use
tSD (avg.) = (tDQSQ + tDV) ÷ 2
and able to find the setup margin and the hold margin.
But in the Write i am not able to calculate the same. Controller and
DDR SDRAM say that it will provide/need 0.45 ns setup and hold time. I
donot have any margin in that case. Can you let me know how do the do
timing analysis for the write cycle.
Thanks and regards
Pinku
PeteS
Thanks and regards
Pinku
Tell us:
1. The exact processor
2. The memory you are using
3. The speed you desire to run at
and then we might be able to help.
I do know that write cycle timing is easier to meet than read for
standard DDR memory.
Cheers
PeteS
Similar threads
F
Replies
1K
fpgabuilder
F
Y
Replies
4
3K
Michael A. Terrell
Replies
1K
Jeff Walther
